Oil change mess
Old Jan 24, 2013 | 07:44 PM
golfblues's Avatar
golfblues
I use this one all the time works great. Punch a hole in the filter with the nail first & let it drain down the slide. Then take the filter off when most of the oil is in your pan. The rest will just feed down the funnel when the filter is removed.
http://www.ebay.com/itm/MOTORCYCLE-D...63f23c&vxp=mtr
Old Jan 24, 2013 | 08:27 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
an empty cigarette carton works well to catch that oil! open it up and the folds help hold the spilled oil.
Old Jan 24, 2013 | 10:02 PM
wlbowers's Avatar
wlbowers
I thought that's what Simply Green was made for.
Old Jan 24, 2013 | 10:05 PM
soft 02's Avatar
soft 02
Like what was stated before SG is caustic to aluminum. If washed off immediately it should be fine but id pass. I used a product called Oil Eater. Its caustic but safer than SG.
Old Jan 24, 2013 | 10:23 PM
zworld's Avatar
zworld
Jeez, just use some rags whats wrong with you !
Old Jan 24, 2013 | 11:47 PM
Cygnusx51's Avatar
Cygnusx51
I just pee off any oil that spills out. It marks my spot and keeps ******** from touching my bike when I'm not around
Old Jan 25, 2013 | 08:05 AM
Lakerat's Avatar
Lakerat
Sandwich bag, non zip-lock style after breaking the filter loose.
Old Jan 25, 2013 | 10:21 AM
Wide_Open's Avatar
Wide_Open
I just cut up a 2 liter soda bottle and clean up the rest with brake cleaner.
Old Jan 25, 2013 | 10:39 AM
SoonerSoftail's Avatar
SoonerSoftail
Slide a cut up 2 liter pop bottle under the filter. Use an awl to punch two holes in the end of the filter, one at the top and one at the bottom. Go have a cold beer or two. Come back and remove the now empty filter.
Old Jan 25, 2013 | 11:25 AM
IronAss's Avatar
IronAss
Originally Posted by soft 02
A little oil on the front keeps things from rustin up....
I think it was intentionally designed that way for a couple of reasons, one of which soft 02 has stated. Another is to aid in our being able to ride more by lessening the amount of time we have to spend washing and cleaning our bikes. The area around the oil filter can be difficult to get to with the Regulator and CPS plug with it's associated wires being in such close proximity.
Having the oil around that area not only acts as a rust inhibitor, it also facilitates bugs just sliding off when they hit that area, thereby saving us the time consuming task of trying to remove all the dried bug guts in a difficult to reach spot.
Makes sense to me anyway.
