Saddlebag questions for Deuce
Old Feb 8, 2007 | 08:38 PM
Jonny Cannon's Avatar
Jonny Cannon
Default Saddlebag questions for Deuce
As a matter of personal preference, I don't like driving with saddlebags all the time. At best, I'd probably use them once a month.
I have a hell of a time putting the saddlebag brackets on and bolting them to the inside of the rear fender. If someone knows a great trick to do this ultra-quickly, without removing the back wheel, etc, I'd really like to know, as that would solve my problem. My big sausage fingers don't fit so well under there, and combine that with a wrenchor aratchet which will only tighten one click at a time, and I'm on the verge of apoplexy a la Donald Duck.
Here's question number one - anyone have the saddlebag kit for the Deuce that bolts to the inside of the rear fender, that has a 180 tire? Any fitment concerns?
Question number two - yes the saddlebags are quick release with the two bolts inside which removes the bags and the sideplates. However, I'm left with that small bracket which wraps around the back of the fender. No problem, except the studs to bolt the bags to stick out from the sides of the fender (two on each side). Chromed or not, you're still left with these long "pegs" sticking out on either side of the rear fender. Bleah. Does any manufacturer make a bolt-on cover or something neat that covers these if you're not using the bags?
Thanks in advance. I've got my new rims & tires waiting to go on, and I thought I'd ask before I go any further.
Cannon
Old Feb 8, 2007 | 11:56 PM
NY Deuce's Avatar
NY Deuce
Default RE: Saddlebag questions for Deuce
I'm not sure if you have a solo seat or a two-up seat with a sissy bar on your bike. If you have the two-up seat with sissy bar you could always go with a T-Bag or SAC bag on the sissy bar instead of the saddlebags. I think it's a much cleaner look because it sits up high on the back and doesn't hide the sides of the bike. You also wouldn't have to worry about the saddlebag support brackets or the bolts when you're not using the bag. Just lift the bag off the back of the sissy bar, walk away and you won't see any extra hardware on the bike. It's just a suggestion but you might want to check out this alternative to saddlebags.
Old Feb 9, 2007 | 09:42 AM
woosh's Avatar
woosh
Ghost Brackets or Easy Brackets. After the sadlebags are removed, all that is left is a short piece of chrome about 4 inches long on the rear fender.
Old Feb 9, 2007 | 09:50 AM
firestarter's Avatar
firestarter
Just ordered the easy bracket and am waiting for it to arrive. You can see the easy bracket on woosh's Deuce
Old Feb 9, 2007 | 07:24 PM
Jonny Cannon
I saw that. It looks pretty good (or at least the best I've seen so far). I have what looks like the "Boss Bags" (came with some parts when I built the bike) setup.
I bought the hard barrel bag from Kuryakyn for my luggage rack on the sissy bar. It fits nice, but rocks back and forth unless you bungee the daylights out of it, so I've made an aluminumbracket that slides over my luggage rack (almost like a sock), and then the bag sits on it and cable ties to it. One strap holds the whole deal on, so it can be removed quickly, and you can't see it.
Cannon
Old Feb 9, 2007 | 07:59 PM
voodoo93's Avatar
voodoo93
I keep my bags on all the time (of course they don't hold much )
El Chiguete
Feb 12, 2010 02:29 PM
dreamer65
Sep 29, 2009 11:03 AM
2001 Softail Deuce
Jun 30, 2009 03:22 PM
jeg1
Mar 13, 2009 05:41 PM
christo
Feb 9, 2005 09:40 PM
