Softail Slim - need wiring help...
Old Mar 22, 2013 | 10:12 PM
  #31
Stebo200's Avatar
Stebo200
Stage III
Default No codes?
Jam,
I went back into Diagnostic mode and cleared the codes. Installed Can adaptor and no codes returned and all turns still working perfect. I didn't start it though as its late and freezing outside here in NY.
Tomorrow i will back her out of the garage and fire it up and see if any codes trip.
I really appreciate all your help ! YOUR THE MAN
As for the CD LED turns ... I haven't seen a brighter or nicer looking turn on a bike.! Very happy with this purchase and highly recommend.
Thanks
Old Jun 26, 2013 | 09:51 AM
  #32
Bulldog211's Avatar
Bulldog211
Jam,
I wanted to take a moment and thank you for this Thread!
I followed your directions from the wiring diagram and the instillation could not have gone more smoothly! The only thing i did differently, was I fabricated costume brackets to mount the LED light bar. I also secured the wires with 200MPH Gorilla Duct tape under the fender.
Thanks again for this post! This thread makes the LED up grade from Custom Dynamics so easy!
Old Jun 26, 2013 | 09:59 AM
  #33
jam436's Avatar
jam436
Originally Posted by Bulldog211
Jam,
Glad it was useful...!
Old Jul 2, 2013 | 05:53 PM
  #34
okie37's Avatar
okie37
6th Gear
I just installed the turn signals on my 2013 slim and it works fine and doesnt have any error codes, not yet anyway. I have'nt driven it, only started it up and tested.
Old Jul 5, 2013 | 07:54 AM
  #35
sts2012's Avatar
sts2012
4th Gear
Default CD install questions
Can some who has installed the CD dynamic clusters LEDs on their Slim tell me if the turn signals lights come on steady with brake application.
Ive installed the CD dynamic cluster on my 12' slim and they seem to work fine if I were in the US but I am in Japan, and the amber turns come on steady with brake application. This apparently is not ok in JP. Looking at the wiring diagram, its a function of the Can system and the BCM. I had a local dealer program the BCM for international settings, but it didnt change the tail light problem. I have the CAN-BUS adaptor installed correctly. I am waiting on HDI LED light from HD but I dont see how the tail light/brake/running light assembly will fix the problem. Any one run into something similar??
Old Dec 2, 2013 | 11:34 PM
  #36
cronk16's Avatar
cronk16
nice slim there!
Old Dec 3, 2013 | 09:58 AM
  #37
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
Man, the color of your bike always gets me, Cronk. What color is that? Only thing I've seen that is as sweet as black and chrome.
Old Dec 3, 2013 | 01:14 PM
  #38
Cougar1959's Avatar
Cougar1959
Default Wig/Wag brake modular
Jam, I have a new 2014 Slim. I ordered the Wig/Wag brake modular. This is suppose to be install on the brake wiring. ( i think ) Do you by chance know, which side of the wiring harness, this should be installed on. The male or female side?
Roy
Old Dec 3, 2013 | 01:20 PM
  #39
jam436's Avatar
jam436
Roy
Go back and look at the diagrams I posted.
The Slims don't have a dedicated (center) brake light, so that wire coming out of the harness is not used.
You should have four wires coming from the harness to the plug under the seat (one for each signal, left and right), but only three running back to the lights. One wire gets dropped at the connection - this "extra" unused wire is your dedicated brake light circuit...
See here (page 3):
https://www.hdforums.com/forum/11059961-post24.html
Old Dec 3, 2013 | 01:36 PM
  #40
Cougar1959's Avatar
Cougar1959
That is what I thought, but wanted you, the wiring Guru, to confirm that.
Thanks Jam.
