New Wheel
Old Feb 23, 2013 | 09:23 PM
Forge's Avatar
Forge
Default New Wheel
Hey folks,
I just picked a new wheel that had the wrong size bearing etc... in it for my bike. It had a 1 inch setup. I had them change it to a 3/4. If I stick my finger inside the bearing I can lift up and down the inner sleave (enough movement where it rattles back and forth). Is this normal?
Old Feb 23, 2013 | 09:53 PM
Forge's Avatar
Forge
It moves enough when I push it down you can catch the top of the sleave (outside of sleave not inside) with your finger nail. If I lay the wheel on its side I can see daylight on the inside of the sleave and on top of sleave. Maybe I am worrying over nothing. Maybe the bearing are what keep things tight.
Old Feb 23, 2013 | 09:57 PM
QC's Avatar
QC
I've never messed with them, but my impression is the spacer should be snug in there. Hogpro is a sponsor in here, try to PM them to see what they say.
Old Feb 23, 2013 | 10:02 PM
Forge's Avatar
Forge
Will do QC --good idea.
Old Feb 23, 2013 | 11:03 PM
Shakey Softail's Avatar
Shakey Softail
The spacer in the hub shouldn't move around the bearings ride up against the spacer also if you noticed the new wheel bearings when pressing into the hub can't be turn by hand or finger if they do not installed right or old bearings making sure you do your spacing correctly when the wheel axle size change so does the spacing
Old Feb 24, 2013 | 08:29 AM
spydyr's Avatar
spydyr
Ditto.. it should NOT move AT ALL. I would not ride it until this is fixed.
Old Feb 24, 2013 | 10:16 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I just realized you are talking about the crush tube. It should be in there tight. If it is not what can happen is it can wear out the bearings. Get a crush tube in the proper size and length and put it in the wheel. I can make one for you. Call me Monday.
Old Feb 25, 2013 | 09:55 AM
Forge's Avatar
Forge
Wen back to stealer to give them a chance to fix but of course they didn't know chit. The Crush sleave is tad to short (came from Harley kit). Strealer tried to say a little play won't hurt anything. Its a ball type bearing! He is full of crap. Too to my Indy (shold have done that to begin with). He is fixing it.
Old Feb 25, 2013 | 03:12 PM
oct1949's Avatar
oct1949
Originally Posted by Forge
Hey folks,
I have no Idea what Ur talking about....
Seem like U bought a wheel with 1'' bearing, U needed 3/4'' bearing and now after U have them change them U can still get Ur finger in them...
Hooly Chit... they must be really loose... and No that is not normal....
U need to either learn how to explain things or take Ur bike to some one who knows what the frig they are doing.....
BOARGAURD
Wheels/Tires
Aug 7, 2015 08:34 AM
azbigb
Dec 1, 2014 05:48 PM
Road Star
Wheels/Tires
Jan 22, 2014 11:18 AM
deerslayer1543
Wheels/Tires
Aug 8, 2009 09:12 AM
vetto
Wheels/Tires
Jan 30, 2009 02:37 PM
