Wheel bearing question
Old Jan 16, 2014 | 11:22 PM
Road Star's Avatar
Road Star
Default Wheel bearing question
Installing new wheel bearings in some mags I picked up.
On one side of the front wheel I can pull the bearing out by hand, if I get it just right. It just slips in, however, it is very close, you have to have the bearing perfectly straight and it slides in. The outer race does not spin once it's in.
Is this OK?
Old Jan 17, 2014 | 08:01 AM
hardheaded's Avatar
hardheaded
that seems pretty loose. does the bore of the wheel look scared up? i would be concerned about the bearing spinning inside of the wheel bore. maybe take some measurements of the bore size and the bearing and see what is allowable. most of the time that bearing has to be pressed in.
Old Jan 21, 2014 | 02:05 PM
Road Star's Avatar
Road Star
I talked to a couple machinists at work, they recommended using the Loctite 680 GREEN. They said it is used to secure bearings in place. The only negative, it would require heat to be removed.
Another option would be a .0005 shim stock.
Old Jan 22, 2014 | 07:55 AM
grbrown's Avatar
grbrown
No it isn't OK! It is highly likely the entire bearing will turn in the hub while riding, IMHO. The green Loctite is the only 'repair' I personally would try, otherwise replace with another wheel (and destroy that one!).
Old Jan 22, 2014 | 07:57 AM
hogcowboy's Avatar
hogcowboy
+1 This is your life you're playing with.
Old Jan 22, 2014 | 11:18 AM
lt1-xjs's Avatar
lt1-xjs
This is correct, we used it to mount sleeve bearings to shafts. There was also a primer that was used to clean and activate. Most likely the ***** will probably fall out before the race would spin.
Ozark Joe
EVO
Jan 4, 2017 12:39 PM
p51bombay
Aug 13, 2016 10:56 AM
beammeup
Wheels/Tires
Aug 16, 2015 04:44 PM
packrat56
Panhead
Apr 16, 2011 05:47 PM
rodney123456
Apr 5, 2010 03:57 AM
