Anyone deal with this? I installed an aftermarket AC with larger breather bolts and noticed my first time out, oil sitting on the bolts. I've read about this and hear it's a pretty common occurence with 95+ big twins especially when ran harder. I was riding pretty aggressive that day and figured that was the issue. So, the question is, what to do? Hydraulic oil pump and new cam plate help this out at all?
Harley actually updated the breather assemblies, under the rocker box covers.
The new part number is 17025-03A.
They apparently work much better than the stockers, and even though they were introduced in 03, they weren't standard until 2011.
Some people will suggest running the oil level lower as well.
Any idea on how difficult it is to install? I want my rockers powder coated and I need to fix the gas line hole, so it could all be done at the same time.
Not hard at all.
Remove the the tank and rocker box covers.
The breathers are right under there in the middle of the two rocker arms.
Should be two 3/8" bolts.
change them out for the new metal assembly's.
There not expensive either.
Not hard at all.
Spot on. They are cake. It will be harder to pull the gas tank than it is to replace the breathers.
Just make sure to get new gaskets for the rocker boxes.
If you are pulling the the lower rocker boxes too, you'll need to make sure the cylinder is on the base circle of the cam shaft to remove the rocker assemblies. Basically, base circle means the valves are closed and the pushrods have no tension on them. With the rocker covers off, this is easy to see. Must be done for each cylinder too.
You can turn the engine by being in 5th gear and spinning the back wheel.
Little curious why you say you have oil on the bolts. I assume you are talking the bolts at the valve covers and not the filter cover bolts. With an open filter you are going to get a few drips from bottom of filter down on the cam covers especially if you let the bike sit for a few week and then run at speed in the 4000 rpm range. If it's the top bolts, sure you did gasket or o-rings correctly?
I have the newer breather assemblies in both of my 2002 95" builds and one still blows plenty of oil. The other has a Pm assembly that comes with rubber boots for teh end of teh breather bolts that directs the blow by back into the intake. So what I am saying is that there is no guarantee that the newer breathers will fix the issue although they are definitely "new" and improved compared to the older ones.
