oil leak from stator plug
Old Apr 1, 2013 | 11:23 PM
Bingee's Avatar
Bingee
I've been researching how to fix that leak on my '09 RKC and now I'm going to give it a try using the 2black1's method. Got some Permatex Black RTV and will use that unless somebody has something better. I've got the outside surfaces very clean and oil free. Used brake cleaner and electronic parts cleaner. Thinking about maybe trying to clean the plug surfaces in the hole somehow. I have a syringe to inject the RTV into the hole and around the plug. But need to get it clean first. Has anybody got ideas how to do that?
Old May 24, 2018 | 12:13 AM
eek88dj's Avatar
eek88dj
Default 1988 1340 EVO Softail FXSTC
The stator plugs leaks also but its different from the newer ones. The plug come through the primary case sticks up through the regulator plugs in it 2 prong regulator. How will RTV gasket work on this. I would have to take the primary apart.
MJHJEA
EVO
Apr 14, 2014 07:11 AM
2006FLST
EVO
13
Apr 1, 2011 03:49 PM
brwdarr
EVO
Oct 3, 2009 06:26 PM
rockerrendell
Aug 26, 2009 09:40 PM
dgretz
Dec 5, 2008 06:21 PM
