Exhaust question
Old Mar 25, 2013 | 11:39 AM
FLSTCI124"'s Avatar
FLSTCI124"
6th Gear
Gents,
The diameter of the exhaust is too large to even fit inside the exhaust port to allow it to even get close to the exhaust gasket.
I've contacted J&P Cycles Tech Support and they said this is a first....
They want the dimensions of the exhaust port and the exhaust pipe.
Old Mar 25, 2013 | 01:17 PM
30glock's Avatar
30glock
Originally Posted by FLSTCI124"
Well klf33,
I'm currently sitting in Kabul, Afghanistan
Thank you for your service...
Old Mar 25, 2013 | 03:39 PM
jreichart's Avatar
jreichart
First off, all of us here appreciate everything you guys are doing over in the sandbox. Thank you for your service!
As for the pipes, that does sound a bit odd. The pipe should fit into the exhaust port opening and seal up against the gasket. It won't necessarily fit 'into' the gasket, but it should definitely make contact with the gasket so that tightening the nuts will crush the gasket and create a seal. If the pipe isn't even touching the gasket, something is off.
Good luck, I dig those pipes! Don't see them around too often, maybe it's cause they don't fit? lol Be sure to post up some pics once you're back stateside! Be safe!
Old Mar 26, 2013 | 12:19 PM
FLSTCI124"'s Avatar
FLSTCI124"
6th Gear
30glock and jreichart you are certainly welcome!
jreichart that is exactly the point I've been trying to get across. I just couldn't believe they won't fit into the exhaust ports like my RB Racing pipes did on my previous 124" build.
J&P Cycles wants me to send them the measurements of both the exhaust port and the pipe diameter.
I have a long ride to Sturgis in August and don't get back to the states till July so I should have enough time to find a set a pipes (that fit!) as close to this style as possible in time.
Old Aug 2, 2020 | 05:57 AM
wamboltwill's Avatar
wamboltwill
Stage II
Default torque tubes
recently switched from 2-1 to straight pipes on my 98 fatboy tried installing torque tubes but exhaust studs are not long enough are longer studs or thinner flanges available?
Jersey Drew
Aug 27, 2014 09:21 PM
splitting_lanes
Exhaust System Topics
Mar 23, 2009 10:32 PM
Twan
Feb 17, 2009 08:38 PM
chuck2000RK
Jun 10, 2008 09:30 PM
campdreamer47
Aug 29, 2006 10:31 PM
