apes... again
Old Mar 26, 2013 | 08:11 AM
slim12's Avatar
slim12
Default apes... again
I know you guys are probably tired of ape threads but need some advice on height. Im goin with santee standard apes but dont whether to do 11" or 14". Im about 5' 10" on a good day and really concerned about comfort. I wanna be able to lean back a little or at least be straight up. I also dont wanna worry about arm fatigue. Which size do you guys recommend?
Old Mar 26, 2013 | 09:17 AM
SanJuanRon's Avatar
SanJuanRon
Personally, I would recommend the 14" over the 11". However, you should use the broom method (hold a broom out to where you are most comfortable and have someone measure the height - and width). I have 17" and 18" (6-0) while a friend who is 5-9 has settled on 14". Keep in mind the width and pullback are also factors to consider. SJ Ron
Old Mar 26, 2013 | 09:29 AM
tbonetony06's Avatar
tbonetony06
I took a shot in the dark and went with 16", 1.5" Gangsters. I am 5'10" and I have zero experience with apes. I hope I am right because I put a ton of $$$ in them because I am going with all internal wiring and cables which means I had to change my clutch system. I just had my chest cracked open, triple bypass, and I am concerned with comfort as well with being so sore and while on the mend. I am told it can take up to a full year to fully heal but that I should be able to ride after a few months. I hope so! The only thing I had to go on was advice from all those here who have gone before me. I have had guys here tell me that going to apes was the best thing they ever did as far as fit and comfort goes and had the other half tell me they just don't like them. I am anxious to see where I fit in at on this topic and mod.
Old Mar 26, 2013 | 09:34 AM
Kowan's Avatar
Kowan
Here's the broom method.
I'm 5'8" on both good and bad days... and mine are 13.5" tall and the same width as the stock bars were.
I sent Bill the measurements I wanted with the knowledge that mine would be mounted in line with the front end.
I sit straight instead of leaning forward to grab the bars and they are slightly lower than my shoulders.
Old Mar 26, 2013 | 09:36 AM
elizer's Avatar
elizer
i went with 14 in carlini pist apes. Im 6 ft. They aren't on yet but 14 was high enough for hte look i thought 16 would be too high.
Old Mar 26, 2013 | 09:40 AM
wheelzk's Avatar
wheelzk
Go with at least the 14's. Every time I read someone debating the height issue it ends up with regret on the short ones and thinking they could of gone even higher on the taller ones. Either way taller bars are more comfortable IMO
Old Mar 26, 2013 | 09:56 AM
slim12's Avatar
slim12
How to spec out and measure up your bike for your new custom bars - YouTube
Thanks for the link kowan, i'll have to try this later today
Old Mar 26, 2013 | 09:57 AM
slim12's Avatar
slim12
I've heard carlini's run higher than what they say, was this true for you?
Old Mar 26, 2013 | 10:00 AM
Kowan's Avatar
Kowan
Every post I've read about Carlini's bars state the same. The bars are taller than listed as.
Old Mar 26, 2013 | 10:05 AM
wheelzk's Avatar
wheelzk
Same as the Yaffe monkey bars. Everything I read states that 14"s perch more like 15 or 16"s
