rear axel covers
Old Mar 28, 2013 | 08:38 PM
bigblock59's Avatar
bigblock59
Default rear axel covers
how hard are these to install? i read the directions and to me they are as clear as mud.
http://www.harley-davidson.com/media...08_M_233d7.jpg
Old Mar 28, 2013 | 08:57 PM
snip0721's Avatar
snip0721
very easy. brackets slip in behind axle adjusters. if you do one side at a time there is no need to dismantle axle. just loosen, install, and re-tighten axle. covers attach to brackets with small bolts.....steve
Old Mar 28, 2013 | 08:58 PM
QC's Avatar
QC
There should be a bracket that mounts between the adjuster locknut. Loosen the locknut without moving the adjuster bolt enough to slide the bracket in between the frame and the locknut. Tighten the locknut. Slide the cover from the back end over the axle so that the clip at the rear of the cover engages the back side of the tail of the swingarm and the front of the cover fits over the bracket. install the 2 little screws on the front and tighten the clip at the rear.
Old Mar 28, 2013 | 10:12 PM
Bone Doc's Avatar
Bone Doc
Like snip and QC described, it is an easy install.
Old Mar 28, 2013 | 10:16 PM
Jake911's Avatar
Jake911
10 minutes if you follow above. Don't forget the blue loctite.
Old Mar 29, 2013 | 12:43 AM
ber1200c's Avatar
ber1200c
The kuryakyn covers come with good instructions. (All kuryakyn products have good install instructions.)
what_the?!
Wheels/Tires
Jul 6, 2014 02:25 AM
SgtThump
Jan 24, 2008 07:11 AM
96 Wide Glide
Jan 23, 2008 10:29 PM
Softcat07
Sep 16, 2007 07:34 AM
SMSgt B
May 13, 2007 05:09 PM
