Sticky shifter - oring question
Old Apr 18, 2013 | 07:14 PM
moomba's Avatar
moomba
Default Sticky shifter - oring question
I have a sticky shifter. I will be removing and cleaning the shifter to remove and corrosion or debris, then change the seals, lube and replace.
Can anyone tell me the size of the orings part 11191? I would rather just run to Home Depot instead of all the way to the Harley shop
Old Apr 18, 2013 | 11:10 PM
Cygnusx51's Avatar
Cygnusx51
Hey man I don't know the exact size off hand but if you're gonna take it apart, just take an o-ring with you to match up. The o-rings don't really do a good job of keeping the crap out of there anyhow.
Also, mine was sticking, along with the brake pedal. I took them both apart and lubed up the shafts with anti-seize. Haven't had a problem since
rome304
Oct 17, 2013 10:18 AM
Challenger
May 15, 2011 11:16 PM
fire228
May 15, 2008 05:20 PM
Mikeeeeeeeeee
Sep 6, 2007 08:31 AM
jack gradolfer
Jul 17, 2007 07:02 AM
