2002 FAt Boy Fuel Tank Swap HELP????
Old Feb 18, 2007 | 05:57 PM
PREDATOR's Avatar
PREDATOR
3rd Gear
Default 2002 FAt Boy Fuel Tank Swap HELP????
I have a 2002 Fat Boy Carb Bike. I would like to swap the tins out to a new HD 2006 Tins set. Fuel injected. What problems will Im have with the swap? Thanks, Kevin
Old Feb 18, 2007 | 06:23 PM
zoomie67's Avatar
zoomie67
Default RE: 2002 FAt Boy Fuel Tank Swap HELP????
There are different fuel valves for the EFI and Carb models. You will have to swap those out.
Old Feb 18, 2007 | 06:52 PM
PREDATOR's Avatar
PREDATOR
3rd Gear
Is that the only changes I would have to make to put a 06 Fuel Injected tank on a 02 Carb Bike? Thanks, Kevin
Old Feb 18, 2007 | 09:51 PM
chops's Avatar
chops
There is a complete kit to do it, it covers up the pump plate.
You can use an EFI tank on carb, but obviously you can't use a carb tank on EFI.
Old Feb 18, 2007 | 10:09 PM
PREDATOR's Avatar
PREDATOR
3rd Gear
Any other issues?? Would this kit be available through HD or aftermarket? Thanks Again....Kevin
Old Feb 19, 2007 | 03:30 AM
bamclean's Avatar
bamclean
Buy the petcock fitting adapter from HD along with a pump plate gasket and just make your own block off plate. I made oneup so I could strip and seal the inside of tanks before paint, and it took less than an hour. Might save you a bunch of $$$.
Old Feb 24, 2007 | 09:24 PM
PREDATOR's Avatar
PREDATOR
3rd Gear
THANKS
96 Ultra
EVO
16
Oct 30, 2017 05:19 PM
wildfonz
Carburetor Related
May 15, 2015 12:15 PM
thelawnmowerman
Jan 29, 2012 05:20 PM
mcfaddenfxdx
Nov 26, 2008 07:46 PM
bv
Exhaust System Topics
11
Mar 3, 2008 12:59 AM
