float adjustment
Old Apr 27, 2013 | 12:22 PM
big brandon's Avatar
big brandon
6th Gear
Default float adjustment
how to you adjust the float if its not closing all the way on a 95 fatboy
Old Apr 27, 2013 | 12:26 PM
freenez's Avatar
freenez
Bend the tang, more likely the float valve or seat is cruddy. Good luck.
Old Apr 28, 2013 | 05:15 AM
Spanners39's Avatar
Spanners39
Yeah, check its not just full of crap but the way to adjust it is to hold the carby, with the float bowl off and the hinge on the float at the top.
Turn carby so that the front (the part that goes in the manifold) is 15-20 degrees off horizontal.
Measure the distance from the gasket surface of the carby body to the top of the edge of the float that is opposite the hinge. It should be 10.5-11.5 mm.
Bend the tang at the hinge end to adjust.
Hades02
Carburetor Related
Dec 29, 2016 05:59 PM
capriceguy
EVO
Apr 7, 2012 08:34 PM
slyder
Exhaust System Topics
Apr 5, 2012 10:45 AM
flstf93
EVO
May 1, 2008 02:27 AM
jimijet
Jun 4, 2005 10:32 AM
