the manual says
Old May 5, 2013 | 08:35 PM
Jackie Paper's Avatar
Jackie Paper
I find it's better done with the stand on a 2x4, but that's just me. Just do not turn the bike over. If it's your first time, be sure once you screw the adjuster all the way in, then go a couple turns further to be sure any thread burrs are smoothed off and then out and back in a couple time pulling in the lever and letting out till you are sure that you are starting you back off from zero free play. It's real easy for a first timer to get too much free play in it..Happens all the time. What amazes me is once you put a few 1000 miles on a clutch and adjust it, unless you drive aggressive, it will change little in 40K. I had to pull my primary apart for a spline that went out in alternator rotor, and I checked everything at 40K. The fiber and steel disk had less then .001 wear.
0204665J
Apr 14, 2013 08:39 AM
Hooter1
Dec 21, 2009 01:37 PM
rjmac53
Mar 24, 2008 07:21 AM
scag52
Jul 22, 2007 02:43 PM
hd_sob
Nov 1, 2006 03:35 PM
