Front fork
Old May 6, 2013 | 09:52 AM
tmilo1000's Avatar
tmilo1000
Default Front fork
What is the difference between the 1999 41mm front forks and the 2000-2006 41mm front forks? Found a deal on some chrome sliders and wondered if the 1999 would fit the newer bike.
Old May 6, 2013 | 10:40 AM
klf33's Avatar
klf33
I believe the lowers used a different 'axle' pre 2000, so check that out.
Old May 6, 2013 | 11:54 AM
tmilo1000's Avatar
tmilo1000
According to parts book the part number for the axle is the same for 1999 and 2000-2006. What I am not sure about is the tabs for the brake caliper.
Old May 6, 2013 | 01:27 PM
Shakey Softail's Avatar
Shakey Softail
The fork tubes are the same as well as the axle only different is the fork sliders brake mount and brake that was used 99-84 brake was the same 2000-current same
Old May 6, 2013 | 02:04 PM
tmilo1000's Avatar
tmilo1000
Sorry, I have been up since the wee hours of the day and not quite reading right. Are you saying the brake and brake tabs on 1984-1999 fork sliders are the same as the brake tabs on the 2000 and up or that the tabs on the 1984-1999 sliders are different from the 2000 and up?
Old May 6, 2013 | 02:44 PM
Shakey Softail
Right brake tabs are different 2000 and up brake calipers are longer and 84-99 are rounded short and offset mounts tabs on the sliders are different
Old May 6, 2013 | 02:52 PM
tmilo1000's Avatar
tmilo1000
Thanks for the update. The chrome pieces I was looking at are cheap enough, but if have to change out the calipers, discs, etc, its not going to be worth the cost savings.
Old May 6, 2013 | 03:04 PM
BlackSpecial's Avatar
BlackSpecial
If you're looking for chrome lowers you might check out ***** Shiny.
I got mine from him and they are outstanding!
lucky23
Jan 25, 2016 11:54 AM
BigFokker
Apr 2, 2014 03:28 PM
neverdown
Jun 20, 2011 10:12 AM
bloodlust
Jul 9, 2010 04:00 PM
seeltonc
EVO
Dec 12, 2006 02:29 PM
