XiED
Old May 15, 2013 | 12:39 PM
blkline69's Avatar
blkline69
Default XiED
well, after reading all the good, bad, and the ugly on the XiED's, i took the plunge and ordered it. put them on today, and was blown away. less engine heat? check. much better throttle response? check. more power that i can really feel? check. now i know every bike is different, so before all the haters chime in, just let me say this...it worked like on charm on my bike.
Old May 15, 2013 | 01:30 PM
OIF SuperGlide's Avatar
OIF SuperGlide
I've had mine on for two years and love them. Got rid of my VH Fuelpak and never looked back.
Old May 15, 2013 | 01:31 PM
jam436's Avatar
jam436
I had a similar experience with their ViED's...
https://www.hdforums.com/forum/softa...than-ever.html
Old May 15, 2013 | 02:10 PM
TheTroupe's Avatar
TheTroupe
Your signature reads "2011 FXS V&H pipes, Stage 1 air intake, HD race tuner, Todds Cycle bars, XiED"
Why do you need the HD race tuner and XiEDs?
Old May 15, 2013 | 02:55 PM
Mr.Softy's Avatar
Mr.Softy
Nothing like them for the money.
Old May 15, 2013 | 04:12 PM
blkline69's Avatar
blkline69
because the tune the dealer put on when i bought the bike was still too lean, and i don't want to pay for a dyno tune until i do a cam swap...just because you have a tuner doesn't mean your problems are solved...
Old May 16, 2013 | 01:29 PM
mag11581's Avatar
mag11581
which ones did you put on?
been thinking about installing but cant figure out which ones to order.
regular ones or the adjustables?
2010 fatboy stock a/c kromeworks slipons
Old May 16, 2013 | 02:48 PM
blkline69's Avatar
blkline69
the regular ones, ordered it from nightrider.com part # 100
Old May 16, 2013 | 04:17 PM
jam436's Avatar
jam436
May as well save a few bucks and go with the XiED's.
The lower settings on the ViED's aren't much richer than the factory lean.
I ended cranking my ViED's nearly all the way up to find the "sweet spot", which is basically the same AFR settings already built-into the XiED's...
Old Jun 17, 2013 | 07:44 PM
Tyree's Avatar
Tyree
Will Xieds help? Oil temp is running about 210 (10 mile urban commute/85 degree ambient temp), have random popping on decel.
