Need a tuner?
Welcome feedback and recommendations.
The best tuner is a tough question on a forum. Everyone thinks the one they have is the best. I would suggest you just ask which ones to stay away from. Although someone will no doubt say that "they never had a problem with X tuner and have been running it for X years" you can get a good idea of the problems that people have with some of the tuners.
My $.02 is, unless you plan on tuning it yourself or just installing a canned map and moving on, I would talk to your shop and ask them what they suggest. If you only deal with a Harley Stealer than they will say SERT and that is it. If you have a local indy that you trust, they will probably say a PCV or PowerVision or perhaps TTS depending on if they have a dyno or not. I have a Thundermax because I tune my own bike and like the fact that if I screw up the auto tune will correct some of my mistakes to keep me riding.
There are also three kinds of tuners.
1. Add on adapters that fool the O2 sensors to just add a bit more fuel and compensate for an EPA Lean Tune
2. Piggy back boxes that intercept the signal from the computer and modify it per your additional tune parameters
3. Tuner that modifies the original computers programming with additional tuning parameters.
1-xied's
2-PCV, and most others
3-TTS, SERT
Good luck
By just adding slip-ons, you haven't changed the AFR at all.
Once you add a free flow AC and your engine is breathing better, then yeah, go for it.
If decel pop is your only concern, just get a set of XiED's which will add a little more fuel.
I wouldn't spend $500+ for a tuner just for adding slip-ons...
My research leads me to believe that the Power Vision with Autotune is one of the best units out there. However that unit along with others in their category (PCV, SEPT, Thundermax ...) are really for bikes that are at a stage 2 and above where-as a total engine tuner is needed. They are kinda overkill for bikes that are at only a stage 1.
For an engine that's only at stage 1 you don't require anything more than a tuner that will manage fuel input.
I recommend you upgrade the AC as well as add a "fuel" Tuner.
Once you figure out what AC you want to go with, contact Vance and Hines, tell them the bike, exhaust and the AC you have and ask them what model "Fuelpak" they recommend.
Then go onto e-Bay and start searching for a used "Fuelpak" for around $125 that someone whose moving up to an engine tuner is trying to unload. It might take some time to snag one at a decent price.
The above is what I did and I'm very happy with the Fuelpak and I only have $135 in it.
If I ever go to stage 2, I'll then sell the Fuelpak and upgrade to probably a Power Vision with an Autotuner.
If you are set on buying a new Tuner or don't want to wait for a deal on e-Bay, I recommend going through Fuel Moto and ordering a DynaJet Micro Tuner. It's appears to be a great fuel management tuner and I hear that Fuel Moto's customer support is second to none. Also Fuel Moto will pre-program the unit for you and then help you over the phone "fine tune" it if necessary.
Good luck with your choice.
With the CVO, I agree I'd stay factory and go with a dealer installed SEPT.
I say dealer installed only because you don't want to put your warranty at risk and if you go to an indie you might run into warranty trouble if something fails.
After the warranty expires you can then go to an indie and have it tuned without regard to EPA requirements.
That is what convinced me to go with the T-max in the first place.
Been said many times in here that without a tuner the {1 3\4'' (preferred)} stock motor or 2'' baffles if U have cams and stg1 works better for Rush pipes.
As far as tuners there a lot more choices now days than their was 7 yrs ago when I got my SERT tuner and dyno...
Still, IMO The SERT or now its the SEpST is as good as any and better than most tuners to be use.
I've had mine 7ys and 42k without a single issue and on my Son's last three bikes, his 07 had the SERT and His 09 and 10 he had SEpST installed and he also has never had an issue with them.
We add the tuners on our bikes when we do the STG1 and cams, Then U won't need any more dyno's till U make major engine mods again.
If he or I bought another new bike, we both would buy another SEpST for them.
I am with T-bone above, we like the SE tuners
