Are the $15 rear lowring kits crap?
Old Jun 1, 2013 | 07:18 PM
mikemock's Avatar
mikemock
Default Are the $15 rear lowring kits crap?
are the bolt kits they sale on egay for 15-$20 junk? i want to lower my bike but i so not want air ride and if i can spend $15 on the back then that sounds good. are they a nightmare to install? any pros/ cons or other suggestions would be great.
Old Jun 1, 2013 | 07:39 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Nope. They do the same job as the ones out of the HD catalog. I had a set (from eBay) sitting here waiting to get installed, but I decided the Shotgun Shock was a better for me, so I ended up giving 'em away to someone on here.
Old Jun 1, 2013 | 07:46 PM
jreichart's Avatar
jreichart
They're fine, been running them 2 years now. Bit of a pain to install, shock needs disassembly which requires a press, or a homemade version of a press. Or your local shop can install the bolts on the shocks for a few bucks. Look into the collars from DK as well, been getting some good press in here for ease of install.
Old Jun 1, 2013 | 08:07 PM
mikemock's Avatar
mikemock
good to know. worth the extra change to get one that doesnt require shock removal?
Old Jun 1, 2013 | 08:11 PM
jreichart's Avatar
jreichart
Well, if you're handy and can press the shocks at home then it's not worth it. If you don't want to be bothered, then get the collars. Your local Indy will prob charge about $50 to press and install the bolts, so if you plan on doing that, the extra cost is a wash anyway and you save a bit of headache removing the shocks.
Old Jun 1, 2013 | 08:37 PM
bikerlaw's Avatar
bikerlaw
I have the bolts. Not a thing wrong with them. If I had to do it over, I would spend the few bucks more and get the collars.
Old Jun 1, 2013 | 08:46 PM
Dead Creek Cycles's Avatar
Dead Creek Cycles
Former Sponsor
The bolts are fine if you have the tools and ability to disassemble your shocks and don't mind removing your shocks first. If you're looking for ease of installation and don't want to remove your shocks, the collars are definitely the way to go. They are super easy to install and you can go either 1.5" or 2" to suit your preference.
You can find the kit here:
http://www.deadcreekcycles.com/No-Sh...Kit_p_704.html
And we are offering $5 off to you as a forum member. Just use promo code: hd5bucks when you check out on our site.
Hope this helps.
Thanks guys!
Old Jun 1, 2013 | 08:53 PM
scottsflstf's Avatar
scottsflstf
I have the bolts but I dont have a press. After brainstorming, I ended up jacking my van up and slowly lowered it onto the shock to compress it, worked great. I have it as low as it will go and have purposely hit bumps to see what would happen and have been very pleased.
Old Jun 1, 2013 | 09:10 PM
Misbehaven's Avatar
Misbehaven
Should have done a video of that. LOL
Old Jun 1, 2013 | 09:46 PM
HoggyMtnBreakdown
Here's a good write-up for the for the bolt install from Kiwideuce.
