Primary oil change plus others
Old Jun 6, 2013 | 09:24 PM
moomba's Avatar
moomba
Default Primary oil change plus others
I just changed all the fluids by the book. I put 26 oz in the primary, but I have heard of others using 32 oz. can you guys let me know if you use 26 or 32?
I used the 24 oz in the transmission by the book. Do any of you use anything different.
I did the scavenge of the motor oil. Not too bad.
Old Jun 6, 2013 | 09:28 PM
golfblues's Avatar
golfblues
Check your manual as it depends on the year. My 06 primary takes 26. Others take 32, 38 or more.
Old Jun 6, 2013 | 09:44 PM
drewdown88's Avatar
drewdown88
I used 32 ounces in both primary and trans. 08 Deluxe. Never been over.
Old Jun 6, 2013 | 09:47 PM
Lakerat's Avatar
Lakerat
Correct amount is at the bottom of the clutch basket.
Old Jun 6, 2013 | 10:04 PM
hdgzr's Avatar
hdgzr
I just follow the shop manual, never had an issue...
Old Jun 6, 2013 | 10:06 PM
ynots's Avatar
ynots
Ditto, when the bike is level.
Old Jun 6, 2013 | 11:15 PM
olongapo1's Avatar
olongapo1
Filling the transmission with the correct amount of fluid is a "No Brain-er". Use the service manual specs as a reference but verify the fluid level via the dip stick. As for the primary, again use the service manual as a reference then perform a visual check to insure that the fluid level is just above the bottom of the clutch basket.
Frozen Excursion
Jul 31, 2017 06:10 AM
trunomad
Jun 13, 2017 06:47 PM
dennyo
Feb 23, 2015 08:06 PM
bpd138
Oil Archive (no new posts)
Jun 5, 2014 08:43 PM
2002bigbored
Apr 9, 2008 10:40 AM
