Fat Boy Wheel Question.....
Old Jun 9, 2013 | 07:29 AM
Motorin Mark's Avatar
Motorin Mark
4th Gear
Default Fat Boy Wheel Question.....
Hello, I am a newbie here with a quick question. Will the 2008 and up front fat boy wheel be a direct bolt on to my 2006 fat boy? I like the holes in the newer one. I know the rear is wider, but the front looks the same? If not is there a way to make it work?
Thanks
Old Jun 9, 2013 | 07:47 AM
fatboy1729's Avatar
fatboy1729
Different axle size...
Old Jun 9, 2013 | 12:21 PM
Daddy-O's Avatar
Daddy-O
Axle size is an issue. Also, this doesn't make them incompatible but 2008 are 17" wheels, 2006 are 16".
Old Jun 9, 2013 | 04:50 PM
ChromeJunkie's Avatar
ChromeJunkie
In addition, the 2008 rear Fatboy tire is a 200. The 2006 is a 150, so without a new swingarm, fender and a lot of work, the 08 wheel won't work on an 06.
Old Jun 9, 2013 | 08:57 PM
Motorin Mark
4th Gear
I would think I could change the wheel bearings to work with my stock axle? But I would probably need the 08' up front fender to clear the additional inch in diameter?
Has anybody done this swap?
Old Jun 15, 2013 | 03:07 PM
Motorin Mark
4th Gear
Hello, Anybody?
Old Jun 15, 2013 | 08:11 PM
XARAN's Avatar
XARAN
If its just the holes. Have your wheels cnc machined for holes or slots there are a few places that will do your wheels machining and if you want it chrome or powder
Example
http://gorbysmachine.com/c/48/modifi...orbys-machine/
$125.00
Old Jun 16, 2013 | 07:43 AM
Motorin Mark
4th Gear
Example
$125.00
Thank you, that's not a bad idea, as my wheels are fine I just like the look of the holes.
Cammed
Jul 16, 2016 08:48 AM
gplarryv
Wheels/Tires
Jun 24, 2010 04:53 AM
G wizz
Dec 4, 2008 10:44 PM
wideglidebob
Nov 23, 2008 02:07 PM
SA_Ddave
Aug 14, 2006 06:29 PM
