Deuce Rim Swaps
Old Jul 12, 2013 | 11:18 AM
BigZees's Avatar
BigZees
Avon 170 60Z R17
Old Jul 12, 2013 | 11:24 AM
BigZees's Avatar
BigZees
Next on the list is trimming that big plastic license plate holder. Going to get the drill out after bit, slide the plate up, drill 4 new holes higher on the bracket. Then use it for a template to mark then trim that godawful looking piece of plastic. Will try to get some before and after pics of it as well.
Old Jul 12, 2013 | 01:17 PM
Village Idiot™'s Avatar
Village Idiot™
I just nixed mine completely. I'll have to get some photos. It's probably best to remove it to mod it, but keep in mind, it's a bitch to do. You have to remove the outer strut covers and bolts holding it on. I just took my angle grinder to mine when I was putting on a bigger wheel and tucked the plate light connections up with the turn signal wires. I put a side mount plate with new lights on the axle. WV has vertical plates too, so it's totally legal here.
Old Jul 12, 2013 | 01:34 PM
run1fsr's Avatar
run1fsr
Have you considered dropping the *** end? That bike would look real nice sitting down another inch or two in the back.
Old Jul 12, 2013 | 02:52 PM
BigZees's Avatar
BigZees
Project #2 completed for the week. Scroll saw, a bit of patience, and my dremel with a sanding drum and viola!!! Lost about 1 1/2" of plastic off of the bottom, and 3/4" off of each side. Drilled 4 holes using my license plate holder as a template and the old bullet style acorns to hold her down. The chrome holder actually snaps into place over the plastic.
Old Jul 12, 2013 | 02:59 PM
BigZees's Avatar
BigZees
Smile
Actually I have thought it over. This bike is destined to play the 2 up role. It was my wifes idea to buy #7, so I have to maintain the comfort factor for her. Shortening those shocks makes the ride a tad sharper, and for a softail it rides rather nice with the both of us on it right now. It's not that I wouldn't love to, but I am trying to make it comfy for SWMBO.(She Who Must Be Obeyed) "Pronounced Swimbo" :P
Old Jul 12, 2013 | 03:10 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Here is the end result.
Yours makes more sense then Harley's silliness. Especial since the did not even chrome original rear. I went my way because the front with a new tire on it was $200 and came with a rear Chrome one off a Fatboy. Rear was only 15 x 3, so I sold it on Ebay. I was trying to go your way but never found a good deal and on mine you can barley see the junk Harley put on. I hit it with a bright pad one in a while and when I put a new tire on. HA
suiii15
Jun 6, 2012 06:33 PM
planethax
Wheels/Tires
Sep 1, 2010 03:46 PM
deuce06
May 5, 2010 04:58 AM
JCK
Feb 28, 2010 06:40 PM
haksaw
Feb 14, 2007 02:02 PM
