Only One O2 Sensor???
Old Jun 28, 2013 | 07:54 AM
knlcox's Avatar
knlcox
Default Only One O2 Sensor???
I've been doing a lot of reading about tuners & the XiEDs... If I understand correctly, the XiEDs connect to the O2 sensor wires. So I took a look at my set up and I only have one O2 sensor on my V&H big shots. The front port just has a blank plug. Is this normal?
I bought the bike used about 4 years ago and the pipes were already on it. She ran great but about 6 months ago I added a K&N filter under the stock cover & I've been dealing with increasing decel pop ever since. I installed a fuelpak last week that I got off of ebay really cheaply. While the decel pop is 98% gone, there are other pops/backfires that are new that I'm not happy with. I was think & hoping the XiEDs would help or if they'll work only having one O2 sensor. I don't have the money for a full tuner despite knowing that they are the best way to go. I'm about ready to just yank the fuelpak & reinstall a stock air filter! I just want my baby to run sweet like she used to. Any advise/help would be greatly appreciated.
Old Jun 28, 2013 | 12:16 PM
Mr.Softy's Avatar
Mr.Softy
The front 02 sensor comes out of the voltage regulator box. Did you check inside there to see if there was a wire?
Old Jun 28, 2013 | 12:19 PM
FXDWG12's Avatar
FXDWG12
Did you try tweeking any of the settings?
Old Jun 28, 2013 | 12:41 PM
knlcox's Avatar
knlcox
I'll check the voltage regulator box when I get off work...
I went through V&H little map lookup site... put in exactly what it said. It runs a touch stronger but it's also hotter & the gas mileage is down to add to the increasing backfire. I have no idea which of the 29 modes to tweek.
Old Jun 28, 2013 | 12:42 PM
mswing1234's Avatar
mswing1234
One O2 sensor sounds screwy to me. Do you have a manual?
Old Jun 28, 2013 | 12:44 PM
mswing1234's Avatar
mswing1234
From the FuelPak instructions regarding decel popping:
"The Fuelpak has a function which shuts off the fuel whendecelerating. No fuel=no pop. Obviously the Fuelpak has to turn the fuel backon at some point or the engine would die. Not all popping can be eliminated,but this feature does lessen it. Mode 23 controls the rpm where the fuel isturned back on. Try lowering this by one number and see if it helps you. If youhave done this and have gotten to 14 or your bike is stalling when coming to astop, that is all you can do and you will not be able to lessen the poppingwithout changing the pipes or installing quieter baffles. The popping is notharmful, just annoying."
Old Jun 28, 2013 | 01:06 PM
knlcox's Avatar
knlcox
Thanks, guess I should've done more looking around on the V&H site... I'll try bumping Mode 23 down one or two at a time as I do recall it was up around 32 if I remember correctly.
FREDStr33tbob
Exhaust System Topics
Aug 1, 2023 03:14 PM
Tomahawk309
Apr 30, 2019 06:29 AM
grasscat
Oct 9, 2018 10:21 AM
Andy02
Mar 27, 2018 10:30 AM
Deuce55
Sep 23, 2014 07:11 PM
