Fast idle question.
Old Jul 2, 2013 | 08:39 AM
QC's Avatar
QC
Question Fast idle question.
Hey guys and gals, need a little diagnostic help.
Recently, my '04 FXSTI has been idling between 1500-2000 rpm at cold start-up in the mornings. Temps have been in the mid 50s-60s. This will last for up to a minute before settling down into the normal 950-1050 rpm. In the past, fast idle would last about 15 seconds or so. I have a service manual but not a electrical/EFI manual. Any advice would be appreciated.
Old Jul 2, 2013 | 10:10 AM
Scuba10jdl's Avatar
Scuba10jdl
Doesn't sound abnormal to me at all. As long as it settles back to the correct idle once it warms up there is nothing to worry about.
Old Jul 2, 2013 | 05:24 PM
QC's Avatar
QC
Thanks for the help.
Old Jul 2, 2013 | 05:40 PM
13FatboyLo's Avatar
13FatboyLo
2nd Gear
If you have the ability to access your idle map, I would look at the map and see if something had changed, if it looks normal, then I would not worry about it. If not you can make an adjustment there.
Old Jul 2, 2013 | 07:08 PM
Sgt_Jim's Avatar
Sgt_Jim
sounds normal to me, my '10 Lo does the same thing
Old Jul 2, 2013 | 07:09 PM
soft 02's Avatar
soft 02
Sounds mornal. Mine does that.
Old Jul 2, 2013 | 08:05 PM
the blob's Avatar
the blob
Mine does that too, it settles back to a nice idle
Once i push the choke in! Lol j/k
Old Jul 2, 2013 | 08:20 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Sounds high to me, but if the ECM reads the idle off by +/-200 for more the 5 seconds, it should throw a code P0505 loss of idle speed control. Since you are not seeing that, are you sure your push/pull throttle cable is not just a little off and sticking the throttle slightly open until a little warmth correct it. Before you start it cold again, snap the throttle and make sure there is a slight amount of play in both cables at throttle body and you here the butterfly hitting the stop. I have the 04 electrical diagnostic manual, and I will bone up on the idle control. How close to stock are you? I only get 2000 rpm at close to 34 degrees start up.
Old Jul 2, 2013 | 11:25 PM
QC's Avatar
QC
Not stock. 98" Hillside kit and V&H Longshots. Just started doing this recently. Last couple weeks. Appreciate the ideas. Slapping myself for not thinkin of checking a code or the cables.
Old Jul 3, 2013 | 06:43 AM
SDrake65's Avatar
SDrake65
Obvious is oblivious QC, we are all guilty of it....
BTW, Threw a Bassani RR2 on my 98, pushing 107hp/110tq now. She's running like a Top!!!
