Breakout Lowering Kit
Rocker, yep Nostradamus and I discussed and decided together quite a while ago to install the Progressive springs. Only he had the chance to get them installed right away as his bike was at the dealer anyway. I wanted to wait until I swap my fork legs for chromed ones. Plus one of my fork seals is slightly leaking when it gets hot in summer. Will have that changed under warranty and the dealer will not charge me extra for doing the springs
I think I will try with the springs only first as everyone who's done the change seems to be quite happy with it. Your review also confirms this. Nevertheless I will keep on looking for a good offer on the ricor intiminators. Unfortunately they are really not available her in Germany. Ordering them in US for retail plus shipping plus tax and customs will leave me with a total of appr. US$ 280,-.......not sure I wanna afford that right now.
be surprised if you find the need to!!
Progressive makes a nice set of aftermarket dampers as well- and they do work very good. The only single reason I prefer the Ricor dampers is the Progressive dampers require modifying the stock fork sliders. You have to disassemble the fork sliders from the fork tubes (pain in the ***), drill out the stock fork slider damper valve holes (pain in the ***), and then reassemble the fork sliders to the fork tubes (major pain in the ***).
So with the Ricors it's just "drop in" easy, and equally as effective benefit as the Progressive dampers without the pain in the *** or extra 2-3 hour of shop labor time.
You could always keep the stock dampers and run heavier 15w or 20w fork oil- that would give a bit better damping than stock- but I don't know to what effect.
FWIW-
She's my navigator. While I'm watching out for the texting goofballs, she's looking at street signs and where we're needing to go.
Not surprised...the two inch leaves no travel left. The 1.5 still leaves some travel. I've had my 1.5 collar in for a few years now. Handling is fine. Ride is fine unless you hit something big.
