Gas Gauge
Old Aug 4, 2013 | 07:47 PM
jba900's Avatar
jba900
Originally Posted by knightenforcer
A candidate for switching to a led fuel gauge kit
Seriously, mine used to read full all the time, so
I thought the float was stuck. I opened the efi tank cover to check
and float was bobbing up and down normally.
So I switched to a harley led fuel tauge kit, problem solved
IMHO, stock fuel gauge are hit or miss.
What is the efi tank?
Old Aug 4, 2013 | 08:03 PM
Ron750's Avatar
Ron750
I never rely on gas gauges. I just go by the odometer.
Old Aug 4, 2013 | 08:08 PM
Bone Doc's Avatar
Bone Doc
Originally Posted by 1004ron
I like the look of that !
I'd go without the fuel cap level gauge - if I go this route, do I order two of the flush filler caps ?
Do you have a combination speedo/tach with a fuel level indicator? If not, are you saying that you would go without a fuel gauge? If so you would have to go by mileage.
You can buy the filler caps individually so, yes, you would have to buy two of them.
http://www.harley-davidson.com/store...CatEntryType=2
Old Aug 4, 2013 | 09:30 PM
threadstopper's Avatar
threadstopper
What make, model and year is your scooter?
Old Aug 4, 2013 | 10:51 PM
jba900's Avatar
jba900
2004 H-D Softail FatBoy
Old Aug 4, 2013 | 11:07 PM
jba900's Avatar
jba900
I just got the FB 7-9 . I got the 2 year warranty (I found out later) and I was just looking over the
service agreement and it says it covers all instrumentation
and electrical.
We'll see Tuesday what they have to say about that.
Old Aug 5, 2013 | 01:15 AM
knightenforcer's Avatar
knightenforcer
Mine is fuel injected. The float for fuel gauge sender unit is inside the tank, same as carb bikes I believe.
A lot of times the float get stuck, and gives false readings. In my case the float was moving with the level of fuel, so the oem fuel gauge was bad.
I replaced it with the HD black flush-mount led fuel gauge and cap kit. I really like it so far. Install was not bad either.
Old Aug 5, 2013 | 03:11 AM
jba900's Avatar
jba900
I have FI.
Man, from what i see from your pics. You have a great looking bike
Old Aug 5, 2013 | 03:16 AM
jba900's Avatar
jba900
Thumbs up
Who needs a fuel gauge that's wrong?
Old Aug 5, 2013 | 03:17 AM
08 Night Train's Avatar
08 Night Train
shop on ebay you can save a lot of money for the same thing you get from the Harley shop$$$$$$$$$$$$
