Gas Gauge
Old Aug 4, 2013 | 02:22 PM
jba900's Avatar
jba900
Default Gas Gauge
What do you think about a fuel gauge that sticks at 3/4 of a tank and then empty?
Old Aug 4, 2013 | 02:31 PM
knightenforcer's Avatar
knightenforcer
A candidate for switching to a led fuel gauge kit
Seriously, mine used to read full all the time, so
I thought the float was stuck. I opened the efi tank cover to check
and float was bobbing up and down normally.
So I switched to a harley led fuel tauge kit, problem solved
IMHO, stock fuel gauge are hit or miss.
Old Aug 4, 2013 | 02:40 PM
jba900's Avatar
jba900
Okay, thanks. I'll look into that. Oh,BTW how does that cap come off?.
(new to Harleys, and haven't got a manual yet)
Old Aug 4, 2013 | 02:48 PM
1004ron's Avatar
1004ron
My stock gauge would move to the "E" mark with loads of fuel still in the tank.
I just installed the 70900070A COMBO ANALOG SPEEDO/TACH-5”MPH and it's fuel gauge is far more accurate, with the stock original fuel level sender unit.
Old Aug 4, 2013 | 03:57 PM
nightrain1983's Avatar
nightrain1983
The cap just pops up. Dont twist or pry just wiggle back and fourth
Old Aug 4, 2013 | 04:02 PM
jam436's Avatar
jam436
Agreed. I'm seeing the same thing.
When my tank gauge needle approaches empty, the LED gauge says there's still nearly a half tank left.
And by the amount needed to top it off, it just confirms it.
Old Aug 4, 2013 | 04:46 PM
Bone Doc's Avatar
Bone Doc
Another option is to consider the flush mount fuel cap and gauge kit. It has a very clean look. I have found that the fuel level of the cap corresponds well to that of the analog speedo/tach.
Old Aug 4, 2013 | 05:18 PM
jba900's Avatar
jba900
How far should i be able pull the gauge up?
Old Aug 4, 2013 | 05:52 PM
Wide_Open's Avatar
Wide_Open
Mine reads nearly empty when the tank is still half full. I ignore it and go by the trip odometer. I plan to get the new speedo/tach combo one day here.
Old Aug 4, 2013 | 06:08 PM
1004ron's Avatar
1004ron
I like the look of that !
I'd go without the fuel cap level gauge - if I go this route, do I order two of the flush filler caps ?
