Wrinkle Black Primary Cover ??
Old Aug 6, 2013 | 02:46 PM
shrini23's Avatar
shrini23
Default Wrinkle Black Primary Cover ??
Ride:
2008 FXCWC
I've the PM 2" extended forward controls with a chrome primary outer cover.
I'm planning to change the chrome to a wrinkle black primary cover.
Is there a difference between dyna & softail primary covers?
Part Number:
60758-06A Part Number
Description:
Fits '06-later DynaŽ models with mid-controls.
Part NUmber:
60717-07A
Description:
Fits '07-later SoftailŽ models. Also fits '06-later FLD and DynaŽ models equipped with factory forward controls. Will not fit with Accessory Forward Controls.
someone is selling 60758 on eBay and I thought I'll buy it but wanted to be sure if this will fit my 2008 softail...Can anyone confirm?
Checked with my dealer and he just goes by the book and doesn't know much
Old Aug 6, 2013 | 04:58 PM
magna's Avatar
magna
Far as I know the only difference is the one your getting has a hole in it for the gear lever being mid controls so you'd need a blank for it if your using forward controls, to be dead sure you could check out a Dyna with mids and see if if its exactly the same shape as the chrome cover on your bike.
Old Aug 6, 2013 | 05:56 PM
shrini23's Avatar
shrini23
Can I get an inspection cover which covers the mid mount hole
Old Aug 6, 2013 | 06:01 PM
QC's Avatar
QC
Old Aug 6, 2013 | 06:10 PM
brandon95354's Avatar
brandon95354
Default inspection cover
didnt they quit using inspection covers on 2007 and up softails and 2006 and up dynas?
Old Aug 6, 2013 | 06:12 PM
Misbehaven's Avatar
Misbehaven
Novello makes inspection covers that stick on and some that bolt on.
Old Aug 6, 2013 | 06:15 PM
shrini23's Avatar
shrini23
60717-07A
This part # when you do a search on HD website the picture shows that it has hole in the middle for a mid mount and when I look at each of the derby cover they look identical to me and both of them do have a hole in the middle for mid mount
My chrome cover does not have a hole in the middle
Old Aug 6, 2013 | 06:20 PM
brandon95354
Default mid hole
yes kuryakyn makes a small ten dollar plug, to plug the mid shaft...its about the same size of a nickel.
a 2007 and up softail primary will work, a fatbob or wide glide primary will work also...they dont have a mid mount hole, since they come with forward controls.....fxdc and fxdb primary will work also but if they came from the factory with mids you will need to plug the hole. on ebay you can easily find a primary cover that will fit a softtail and dyna for $75-$150.
even though its just a small plug it is still very visible, so just look for a 2007 and up softail primary....or look for a 2006 and up dyna primary for forward controls.
http://www.ebay.com/itm/Harley-Softa...189d45&vxp=mtr
http://www.ebay.com/itm/Harley-Dyna-...c21671&vxp=mtr
either of these will work.
good luck
Old Aug 6, 2013 | 06:26 PM
brandon95354
60717-07A
hi, shrin on you original post it shows 60717-07A wont fit with forwards, this is only because of the hole for the mid shaft, but the bolt patterns are exactly the same.
if you going to get a brand new one maybe check out kutterharley.com, newcastlehd.com, or surdyke.com i rarely get parts from the local dealer..sometimes these site have 20-30% off =, no tax, free shipping.
but either of the used ones i listed will fit your rocker no problem
av1025
Dyna Parts
Mar 26, 2014 11:59 AM
pehenley
May 3, 2013 05:52 PM
mikey7453
May 21, 2012 06:29 PM
Robbie13
Feb 25, 2012 02:08 PM
timfromfc
Jul 14, 2010 03:39 PM
