Heritage Bars on Deluxe
Old Aug 14, 2013 | 08:26 AM
gchristopher9's Avatar
gchristopher9
Default Heritage Bars on Deluxe
Has anyone else made this swap? Looked but wasn't able to find any pictures. Did it require anything to be lengthened? Brake/throttle/wires??
Old Aug 14, 2013 | 11:10 AM
Benway's Avatar
Benway
I'm guessing you're going to be about 3" short.
Old Aug 14, 2013 | 11:43 AM
gchristopher9
I probably should have clarified that I'm also planning on replacing the stock pullback riser with a 1.5" shorty, so that should help me cause as well. Were you guessing 3" short with the stock riser? If so, replacing it with a 1.5" will likely buy the 3" I would need.
Old Aug 14, 2013 | 02:22 PM
ChromeJunkie's Avatar
ChromeJunkie
You should be ok with 1.5 inch risers. I installed Heritage bars with 1.5 inch risers on my Softail Standard and had no fitment issues with stock cables.
Old Aug 14, 2013 | 03:25 PM
yzergod's Avatar
yzergod
I took Heritage bars off my Deluxe for my apes. The cables were NOT stock if that helps.
Old Aug 14, 2013 | 03:48 PM
jimmers1817's Avatar
jimmers1817
When I put new bars on our 08 Heritage and 08 Deluxe I found that all the stock cables were the same length. So providing the 13s are the same you should have no problem.
Personally I think 1 1/4 bars look better.
Old Aug 14, 2013 | 08:45 PM
Brent Smith's Avatar
Brent Smith
You should be fine with that riser switchout. I have Heritage bars on my Deluxe risers and use 2" over Heritage cables. Looking at a few different charts Heritage cables are 2" over Deluxe, so losing the inches on the risers should give you enough length in the stock Deluxe cables..................I wouldn't think a whole lot of slack though.
Old Aug 14, 2013 | 09:39 PM
snksknrZ28's Avatar
snksknrZ28
Old Aug 15, 2013 | 09:08 AM
Benway's Avatar
Benway
As always, get some string out and measure..
Old Aug 17, 2013 | 05:39 PM
gchristopher9
Made the swap today and everything worked just fine. In fact I could probably put 16" apes on and still use the stock clutch cable. Thing is a mile long. Here are the pics.
