Fuel Line Quick Disconnect
Old Aug 25, 2013 | 04:41 AM
tryus's Avatar
tryus
I had a very similar experience, on the side of the road like the op. Desperate, I bought a bar of soap, and worked it into the groove with the bad o-ring to temporarily seal it. I had remembered a trick I learned about in my teenage years to seal a gas tank that I had ripped a small hole in on my raggedy-*** pickup. Rubbing soap into that hole sealed the tank, and would last several days or a week before I had to retreat it. I drove that sucker all winter one year before finally getting it fixed. Well, it worked, way back then, and last year on my bike, and lasted for over an hour until I got home.
Old Sep 19, 2013 | 02:49 PM
Robert Strohl's Avatar
Robert Strohl
Just had my mechanic work on my bike and it was leaking and still is. Glad I got on here and checked this out. Thanks for the post! Much appreciated!
Old Sep 19, 2013 | 04:44 PM
Runcy12's Avatar
Runcy12
Hope it works out for you. I have logged almost 500+ miles since installing the new o-ring and everything is 100%
Still irks me that H/D won't tell people this.
Old Sep 19, 2013 | 11:17 PM
javierf's Avatar
javierf
6th Gear
Cool pictures
First of all, thanks for sharing that information. I have the same problem after removing gas tank of my 2007 FXST to work on electrical connectors. I lost the O ring so I went to local HD dealer, bought part 11323 but it was too big, apparently for the inside of the tank. Is it the male part that also requires a smaller O ring? I am anxious to get my Softail on the road again!!!
Attached Thumbnails Fuel Line Quick Disconnect-gas-fem.jpg   Fuel Line Quick Disconnect-gas-line.jpg
Old Sep 19, 2013 | 11:23 PM
ynots's Avatar
ynots
If you need the whole connector dont go to HD, you can get it at Napa for cheap.
This is for the hose section, not tank fitting
Fuel Line Connector
Part Number: NOE 7305617
Old Sep 20, 2013 | 03:17 AM
Robert Strohl
Exclamation
I'll find out. I told my mechanic what I read on here and he was like "Cool! Thanks!" He came and got my bike while I was at work and I haven't heard from him since. I'm guessing I'll get a text tomorrow. So I'll let you know how it goes.
Rob
Old Sep 20, 2013 | 03:38 AM
Ron750's Avatar
Ron750
My Indy replaced the internal gas line and connector, on my '03 for $100. He couldn't use the HD parts, since they won't sell them to Indys. He said he put a shorter line in, than stock, because the stock lines were too long and rubbed against the bottom of the tank causing problems, on the '03s. To me it is worth $100, to get it done right, but thanks for the heads up, I will add some o-rings to my tool kit, for future emergencies.
Old Sep 20, 2013 | 04:16 PM
Runcy12's Avatar
Runcy12
No, there are 2 O-rings in the "female" quick disconnect. a upper and a lower. The lower O-ring is the one that typically causes the issue. Advance auto Part #64492.1 is the one I bought, but any o-ring that is 10mm x 14mm x 2mm will work. You will need a small hooked needle and mirror to make sure you have all of the old o-ring bits out before putting in the new one. I used a small flat screwdriver to gently push the new o-ring up into place. Also, I added a small coating of grease to the o-ring so when I inserted the male quick-disconnect in, it would slide past easier and wouldn't snag the rubber.
Again I hope this helps!
Old Sep 21, 2013 | 12:20 PM
javierf's Avatar
javierf
6th Gear
I got the mentioned o ring. Ive been trying for the last hour unsuccessfully. I might to remove female end from tank. This is SO frustrating!!!
Old Sep 21, 2013 | 04:18 PM
Runcy12's Avatar
Runcy12
Make sure you have gotten all of the old o-ring out. Then gently push the new one in by hand, it is slightly larger than the opening and will be slightly folded. Use a small blunt screwdriver or dull pencil and gently work the o-ring up the connector. there is a small groove between a 1/4 to 1/2 in up that the o-ring will seat into. A small mirror and a extra pair of hands can make this easier
