Turn signal control question
Old Sep 1, 2013 | 07:16 PM
lowered907's Avatar
lowered907
Default Turn signal control question
I have an '88 Softail Custom. Currently the turn signal buttons have to be pressed and held to continue to flash while turning. once I let go they stop. Is there any way to change this to only have to press them button once, or press it a second time to turn them off?
Old Sep 1, 2013 | 09:11 PM
QC's Avatar
QC
If there is a turn signal control module on your ride, That may need to be replaced.
Old Sep 1, 2013 | 10:20 PM
lowered907's Avatar
lowered907
There isn't one that I know of. Just a 12V flasher
Old Sep 1, 2013 | 10:27 PM
lowered907's Avatar
lowered907
Hopefully i'm posting in the right place.... New here obviously.
Old Sep 2, 2013 | 12:52 PM
lowered907's Avatar
lowered907
Some one has to have the answer... to the top
Old Sep 2, 2013 | 04:46 PM
lurchus's Avatar
lurchus
Check the TSM(turn signal module). I have an '87 FXR and once I let go of the button, it flashes 10 times, then turns it self off. I'm pretty sure thats the only cancelling that the '80's models had.
Steve
Old Sep 2, 2013 | 04:58 PM
lowered907's Avatar
lowered907
My shop manual, doesn't mention anything about the TSM. I've been through the wiring, and I know where the flasher and the circuit breakers are (under the dash). So any pointers would be helpful.
Old Sep 2, 2013 | 05:29 PM
QC's Avatar
QC
Did you replace the flasher?
Old Sep 2, 2013 | 06:01 PM
lowered907's Avatar
lowered907
Yes sir, i did.
Old Sep 2, 2013 | 06:08 PM
QC's Avatar
QC
Well I would have to think something else is causing this. I wouldn't think both switches would go bad at the same time.
P.S. I'm not "sir". That was my father. Had to turn and to see if he came back from the dead.
