No a blown or shorted bulb will not cause this. Have the dealer check it
But if it isn't doing it at the time he looks at it he won't be able to find it.
No a blown or shorted bulb will not cause this. Have the dealer check it But if it isn't doing it at the time he looks at it he won't be able to find it.
And sometimes even if it is,, they still can't find it..
Out on a short ride now. Right turn signal coming on by itself. Ugh
Mine was having wierd stuff like that happening and I was fearing the worst financially. HD service found a pinched wire in the housing I had done after switching grips.
it seems to have fixed itself. I booked it in at HD for Wednesday so I guess I might as well have them look at it since it's still under warranty.
Just a hint my hd mechanic passed on to me...Mine failed and he had to replace it. He said it is better to leave the EMERGENCY kill in the on position and use the key switch to start/stop the bike. Use the kill switch in case of an emergency. Good luck.
