2011 fatboy coil relocation
Old Oct 12, 2013 | 10:54 AM
FatboyDilbert's Avatar
FatboyDilbert
Default 2011 fatboy coil relocation
Hey I have a question on this. I have a 2011 fatboy and am relocating my horn to the front and the coil to the horn w/ the horn cover and removing the rear coil mounting bracket.
my questions are
1) what size wire is the delphi connector ( looks like 18 or 20 ) so i can solder and extend
2) regarding the relocation to the horn .. I wanna put it under the horn cover and am wondering how others have mounted it bracket wise ( no need to reinvent the wheel as im sure others have done this )
3) how can you lift the tank to run the wires without removing the leads wires etc?
Old Oct 13, 2013 | 03:38 AM
Deadanimal's Avatar
Deadanimal
Not sure on the wire size but your life will be much easier if you lift the tank out of the way enough to get to the harness. I pulled all the wires out and re-routed them after extending them and re-wrapped them into the harness wrap. that part was pretty easy since the wrapping has a tacky strip along one side to hold it together.
You can also swap the connectors in the clip so you don't have to cross your plug wires if you mount it facing down.
I put my horn down on the right side behind the tranny and no cover.
Originally Posted by FatboyDilbert
Hey I have a question on this. I have a 2100 fatboy and am relocating my horn to the front and the coil to the horn w/ the horn cover and removing the rear coil mounting bracket.
my questions are
Old Oct 13, 2013 | 06:25 AM
FatboyDilbert
also .. if im able to find one of the older better looking coils to run bare ... are the older coils ok ( just as good ) to use in place of mine ?
Old Oct 14, 2013 | 12:02 PM
FatboyDilbert
any takers?
scottylonebull
Aug 15, 2014 08:49 AM
jasonleahey
Sep 1, 2013 09:10 AM
Binky
Jan 7, 2013 08:27 AM
spydyr
Jan 16, 2011 10:01 PM
jed1069
Oct 17, 2009 08:46 AM
