Wiring issue?
Old Oct 12, 2013 | 05:06 PM
Flightmast's Avatar
Flightmast
Default Wiring issue?
Hi, I have an 04 Deuce. The rear left turn signal wont work? I have taken it all apart and everything is as it should be. I have a good earth through the internal wire. I have an intermittent current when indicator is on? still no Turn signal? I have put the wires from the holder directly onto the bulb, still no light. I have checked the bulb, which works fine in the opposite side indicator, and yes I have tried other bulbs. still no light? anyone had this problem.
Old Oct 12, 2013 | 05:43 PM
Koafarms's Avatar
Koafarms
Is the current and voltage the same value on the working side?
Old Oct 13, 2013 | 05:16 AM
Flightmast's Avatar
Flightmast
Default Update1
Thanks for this Koafarms, I went back and swapped over the power leads to the turn signals at the connectors in the rear light compartment. and now it works, ... but the other one now does not. So I then checked for continuity from the harness connection under the seat to each Indicator, they have good continuity, both Violet and Black earth. So I then cleaned connectors. still no rear left indicator. At least I now know that the rear end is all working fine, so the problem must be between the connector coming out of the fender and the Security module. My bike does not seem to have a alarm system? someone may have taken it off in the past> I don't have a key fob, just a key? no visible security alarm box?
So the problem lies from the rear light connection to the Security/ indicator module?
what next to check?
Old Oct 14, 2013 | 11:18 AM
Flightmast's Avatar
Flightmast
Default Final update
I have solved the issue with the indicator. The battery was not keeping full charge, it was down to 10v even though it was enough to start the bike it was not enough to power one out of 4 indicators? once the battery was replaced it all worked fine. strange.
Old Oct 14, 2013 | 01:18 PM
Koafarms's Avatar
Koafarms
As someone once shrugged and told me, after bumping the generator and frying all the electronics in a remote work site camp..."Electricity can do strange things....."
Glad you got it solved.
Old Oct 14, 2013 | 02:36 PM
Warp Factor's Avatar
Warp Factor
You still might try to track down a bad connection someplace, if you feel like doing it. Everything else works at 10 volts, except that one turn signal?
Old Oct 14, 2013 | 03:46 PM
Flightmast's Avatar
Flightmast
Default Update
thanks for the advice, I have gone through the wiring quite thoroughly now and the only thing that could have been the issue was the control module, but as its now working , that's unlikely, I think it was just that it did not like a flat battery.
Old Oct 14, 2013 | 04:11 PM
08Nighttrain's Avatar
08Nighttrain
How old was the battery?
Old Oct 14, 2013 | 11:18 PM
Bluehighways's Avatar
Bluehighways
+1 There's another problem there, that a fully charged battery may hide for the moment . . . but I can assure you, it ain't going to get any better and will almost certainly get worse in the course of time.
Old Oct 15, 2013 | 11:28 AM
Flightmast's Avatar
Flightmast
Default update
The battery is not new, it was on the bike when I recently bought the bike. It is a genuine Harley battery, so could be 3-5 years old, now gone and new one fitted. If I do get future problems, then it has to be the signal module, as I have checked and cleaned everything else. Thanks for the assistance.
ssober
Sep 30, 2013 09:21 PM
CopperHead2008
Apr 21, 2011 05:38 PM
wfdmedic8
Oct 6, 2010 06:53 AM
stupid_rope
Apr 21, 2009 02:39 PM
quackhead
Apr 25, 2008 10:34 PM
