So I've been searching all day trying to find a solid answer with no luck. I know a progressive drop in kit will work fine but I'm looking to go lower than 1.5" in the front.
What's the lowest the front forks can go on a FL front end w/light bar, fender, & 23"?
I'm looking to buy -2 tubes but worried they won't work & don't want to waste the cash. If anyone can help me out, I'd greatly appreciate it.
i dont think the 23" wheel will be much of a factor seeing that the rim is bigger and the tire has a thinner side wall.....from what I have seen, the 23" is a little less than 1/2" taller that the 21".... are you talking about a stock fender as well?
