Front End Clunk??
Old Nov 11, 2013 | 08:37 AM
Scudda's Avatar
Scudda
Default Front End Clunk??
Had my 05 fatboy out yesterday for a nice ride. I noticed a clunk sound when hitting bigger bumps coming from the front of the bike. Kind of almost sounds like the tank is jumping . I did check those bolts and they were tight.
I know on my 95 FXDL when I had a clunk like this I had a bad front motor mount
Just looking for some advice
Thanks again!!
Old Nov 11, 2013 | 08:54 AM
fdb2007's Avatar
fdb2007
Could you feel the clunk? Start by checkin all the stuff bolted on the front, ie lights, motor mounts, brake caliper, tank (already done), console, risers, etc. Do you have a jack? If so, jack it up and start shaking the front end down. Have your forks been serviced, ever?
heybaylor's Avatar
heybaylor
do a search for steering head bearing adjustment.
there is a lot of info on how to adjust the bearings ..
My fatboy did the same thing as yours , and after proper adjustment ....zero clunk. only rattles my teeth now on the big bumps
Old Nov 11, 2013 | 10:14 AM
Scudda's Avatar
Scudda
Thanks guys. I know i had the steering head adjusted when I got the bike it was more for a shimmy then a clunk. I will have to start check everything else. The bike still handles great.
The forks will be getting redone this winter I am going with chrome lowers!
Old Nov 11, 2013 | 11:10 AM
oct1949's Avatar
oct1949
how long ago was it when U checked the neck bearings? U could have some flats spots on them or just bad bearings.?
also have U greased them Every yr?.
Noise travels and can be coming from where we don't think it is.
keep looking, U'll find it.
Old Nov 11, 2013 | 11:48 AM
Scudda's Avatar
Scudda
The bearings were checked and adjusted in May of this year. I really have to hit a good bump to hear it...lol
Old Nov 11, 2013 | 05:27 PM
PureDeath's Avatar
PureDeath
You may need to grease the neck.
Old Nov 11, 2013 | 05:31 PM
RANGER73's Avatar
RANGER73
I had a similar problem, turned out to be my shock preload and the fact I had used lowering bolts on my shocks. The swingarm was bottoming out under the seat.
Old Nov 11, 2013 | 07:39 PM
jreichart's Avatar
jreichart
Google search "HD bulletin M-1215". It addresses the front end clunk. The dealer can do a vin search to see if it applies to your bike. Fixed the clunk on my 05 train. The bulletin replaces the thin washer with a more robust one and increases the torque specs. Short term you could just slightly over torque the head nut, but due to the stock flimsy washer, the clunk will eventually return. The washer is about $6 at the dealer. Good luck, hope this helps!
Old Nov 11, 2013 | 07:52 PM
dennyo's Avatar
dennyo
Yup , mind did the same thing New Washer and Tighten-er-up , NO Clunck ...
