Side-mount for FXSB Breakout
Old Jan 6, 2018 | 03:50 PM
  #31
Rocco88's Avatar
Rocco88
6th Gear
Default USA side plate
I purchased all the parts to make this conversion. The side plate has two black wires attached to pins but no plastic clip/plug to plug into existing harness. Any idea where or how they get plugged in. I currently have 3 wires coming from the rear taillight/licence plate light that I am removing that lead to a plug under seat. Any help is appreciated
[QUOTE=Niels83;12004707]You were right 24V. Luckily they let me change my order at HD New Castle. So below is the list of items I've ordered that you need to make the mod from international to domestic. One can choose not to order 69490-07, since it's the same reflector as you already have on the international installation and to not order 59500108, but cut of your original international inner support instead. I've chosen not to bother, since those are not exactly the most expensive parts.
67900145 (LICENSE PLATE BRACKET w/ 67900117)
68702-07 (BRACKET license plate, adjustable)
67800223 (SUPPORT rear lamp mounting (left side only) (Domestic))
59500108 (INNER SUPPORT (Domestic))
67900165 (REFLECTOR ASSEMBLY w/ 67900163 (Domestic))
69490-07 (REFLECTOR red)
Old Jan 6, 2018 | 03:58 PM
  #32
Rocco88's Avatar
Rocco88
6th Gear
Default Side plate wiring
Hi, what did you do with the wiring that comes with stock side plate? Two black wires with pins but no clip to plug anywhere into existing harness . I am removing the rear break / plate light so there is three (brake, plate, ground) I’m assuming wires there leading to a plug, so do I remove those from plug/clip and use same one inserting the two new black wires? Any help is appreciated. Thank you
Originally Posted by Niels83
I live in Europe and unfortunately they decided we need that horrible center-mount plate-thingy to hold on to the license plate. It's a very cheap solution and therefor I really want to buy the side-mount as seen on the USA models. But I can't find it anywhere.
Does anybody have any tips? Or a part-number? I really want the original Harley version, no Küryakyn parts.
Old Jan 6, 2018 | 04:04 PM
  #33
Rocco88's Avatar
Rocco88
6th Gear
Hi, any idea how I wire the stock side plate? Removing the rear taillight/plate combo , it has three wires leading to a plug under seat. This side plate came with two black wires with pins on end but no clip or plug . Do I replace the three wires I’m removing with the two black ones?. Any help is appreciated
Originally Posted by 24v
67900145 should include 67900117 per the OEM part finder. You should not have to order that separate.
67900145 LICENSE PLATE BRACKET w/ 67900117 BF5/BFV
Old May 9, 2018 | 04:13 AM
  #34
Wpgmike's Avatar
Wpgmike
Stage I
Anyone know the inside diameter of the rear axle washer? Going to make a side plate bracket, would rather not take nut off till installation.
Old Jul 2, 2023 | 10:41 AM
  #35
pwaw_whipp's Avatar
pwaw_whipp
Stage I
Default Confirmation of Setup…
Dear Sir,
Can you confirm this below set up you purchased is similar to this image??
Clamped on to the indicator if I see things correctly?
Thank you in advance
Old Jul 2, 2023 | 06:14 PM
  #36
Bone Doc's Avatar
Bone Doc
Originally Posted by pwaw_whipp
Dear Sir,
Welcome to the forum from central Texas, USA.
Niels83 posted that in 2013. He has not been active on this forum since 2016.
Old Jul 5, 2023 | 06:26 PM
  #37
stormin08's Avatar
stormin08
PWAW WHIP....
are you looking for the set up pictured ???
i have that whole set up, in a bag...with he smaller light mount as well....not being used anymore
ramnj
Dec 24, 2013 12:14 AM
Javieret
Sep 19, 2011 06:31 PM
99ls1
May 22, 2011 10:30 PM
NeverEnoughToys
Oct 9, 2010 10:40 PM
vickon
Jan 6, 2008 08:13 AM
