Running like junk and stalling
Old Nov 20, 2013 | 02:21 PM
yzergod's Avatar
yzergod
Originally Posted by Richaf
OK, tried the gas thing. Took it for a very short ride... it ran mint!
I'd follow up the next tank full with an ounce of Seafoam. Glad it was that simple!
Old Nov 20, 2013 | 03:32 PM
Richaf's Avatar
Richaf
6th Gear
Originally Posted by HDmikie
Just a passing thought.......if there are pin holes in the gas line inside the tank, your bike might run great until the amount of gas in your tank goes below the pin holes. Hope this isn't the case, but something to keep in mind while going on a longer ride. Maybe try to stay fairly close to home just in case.
I'm not sure what the inside of the tank on these newer bikes are like (my last was a '73) but I had a little more than 1/4 given that the gas gauge is accuarate. Well, I'd rather have this stuff go wrong while under my extended waranty! Hope it's not the case thogh.
Old Nov 20, 2013 | 05:52 PM
jreichart's Avatar
jreichart
Glad it was nothing major! Had the pinholes in my lines at the beginning of this season. The lines that are in the tank rub the inside of the tank and develop small holes over time. Mine is an 05 train as well, so that might be the culprit. If so, not a hard job, worst part is getting the fuel pump assembly out of the tank. New lines and filter will run $100 or so, and don't forget to replace the hose leading to the quick disconnect, it doesn't come in the fuel filter and line kit. And pick up some extra crimp-on hose clamps, chances are you'll bugger one up.
Old Nov 20, 2013 | 06:02 PM
fcsallan's Avatar
fcsallan
Pin holes will not show until your gas level is below the holes. No question about it, it is the high pressure line in the take. It has a pin hole in it. It happens to more than most bikes of this age. I did mine last year. Simple job, bought my gates hose on Ebay and did it in about 40 minutes and less than a full beer.
Old Nov 30, 2013 | 08:19 PM
Richaf's Avatar
Richaf
6th Gear
Here's the update as promised.
Shop called today after giving them all the info the other day. They did find pin holes in the hoses in the tank and also a faulty check valve. Warranty covered!
Hopefully case closed!
Thanks again for all of the feed back.
Old Nov 30, 2013 | 09:40 PM
QC's Avatar
QC
Thanks for letting us know. Now get riding!!
ZachGrove1
Aug 28, 2018 07:07 PM
Coloradohunter
Jun 30, 2011 11:17 AM
wodom1
Jun 12, 2010 10:57 AM
danktat
Aug 27, 2009 03:17 PM
COFFESLINGER
Jul 11, 2006 03:25 PM
