Front sprocket change
Old Nov 21, 2013 | 12:26 AM
asputin's Avatar
asputin
Youll need a long breaker bar,i had to use a 3 foot pipe on it to get the bolt loose.
Old Nov 21, 2013 | 12:47 AM
star2nv's Avatar
star2nv
Definitely going to do this while the winter us here
Old Nov 21, 2013 | 07:48 AM
Greabert's Avatar
Greabert
I hear ya, I had a heckuva time trying to get that loose and the pulley nut was equally as stubborn.
Old Nov 21, 2013 | 07:50 AM
Greabert's Avatar
Greabert
Good time to do it cuz it'll likely be down for a bit. I think you'll be happy with the results.
Old Nov 27, 2013 | 09:30 PM
Red Eye's Avatar
Red Eye
I'm planning on gearing up too. I don't know how many cogs etc, so I suppose I can't contribute informatively to the thread, but yourself doing it has given me the confidence to start.
I prefer a slower engine rpm when cruising, and I can't count the times, I'd pull the clutch in to shift to 5th and find I was already there.
Old Nov 28, 2013 | 12:25 PM
Greabert's Avatar
Greabert
You're not alone Red Eye, that's what prompted me into swapping pulleys.
Old Nov 28, 2013 | 01:34 PM
bikerlaw's Avatar
bikerlaw
The stock front pulley on my 2005 Fat Boy was 32. I swapped up to a 34 tooth. One of the best mods I EVER did to that bike. Not only does it make for the PERFECT highway RPM, it raises the forth gear shift point. Why does that matter you ask???? Because anyone with a 5-Speed Softail can tell you that one of the most annoying features of those bikes if the 50 mph cruise speed. At least for me, I always seem to be between 45 and 55 miles per hour when I'm not on the highway. The stock gearing is such that both forth and fifth gear always seems to be the wrong gear. I seem to always want to shift up to fifth as soon as I go over fifty, and shift back down to forth all to often. That 34 tooth pulley makes forth gear the perfect gear for anywhere between the high 40's and damn near 60 mph. Almost completely eliminates the "wrong gear" 5-Speed issue. At least for me, that 34 tooth pulley was worth its weight in gold.
Old Nov 28, 2013 | 01:53 PM
Greabert's Avatar
Greabert
Right on the money bikerlaw. I don't have a tach, but do you know what R's we turn at 60mph now? I also swapped over to the 34t front pulley.
Old Nov 28, 2013 | 01:55 PM
QC's Avatar
QC
What did you guys that did the swap do for the speedometer calibration?
Old Nov 28, 2013 | 02:28 PM
bikerlaw's Avatar
bikerlaw
I recently sold the bike, so I can't remember what 60 was. QC, I did nothing. You can have the dealer recalibrate the speedo, but I didn't bother. Based on my GPS and extensive monkey testing, I can say that the speedo went from running a stock 2mph fast to 2mph slow. Meaning stock, actual 70 read 72 on the speedo. With the 34 tooth, 70 read 68.
