Juiced I am in the Waterloo area, how about yourself? A
And thanks for all the info guys it really helps. I may just go ahead and upgrade to the 95 ci at the same time, and clean up the heads at home for a little better flow. Is it possible to pull the cylinders off with the motor still in the bike, I assume there is but not sure if there is enough clearance to get them pulled off of the case. Also it is a carbed engine, I already jetted it, not sure off the top of my head what size but did enough to clean it up since it was running so lean stock.
Thanks again.
There is plenty of room to take everything apart. My photo album in here is full of pics of my build. It's a pretty straightforward operation.
