Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 16, 2014 | 08:41 PM
  #141
BroTim's Avatar
BroTim
Default Rear axle covers
Does anybody know what rear axle covers will fit the standard Breakout. The right side is so short it doesn't give you much to grab on to. For some reason the CVO axle setup is different. I am going to get my bike back tomorrow and will post pictures right away. The chrome swingarm looks awesome!
Old Jan 16, 2014 | 08:47 PM
  #142
24v's Avatar
24v
Harley Charley has axle covers on his. Maybe send him a PM.
Old Jan 16, 2014 | 09:52 PM
  #143
Pa-Rider's Avatar
Pa-Rider
Curious - (and you've probably posted it elsewhere on here) but did you change out your brake pedal lever? Contrast cut? Is it HD or aftermarket - if you did..
Care to post up a pic of that?
Old Jan 17, 2014 | 12:42 AM
  #144
EagleRay's Avatar
EagleRay
As far as I know the Swingarm Axle Cover for the Rocker will fit. That would be P/N 44345-09. If I remember correctly those are the one HC used as well.
Old Jan 17, 2014 | 01:12 AM
  #145
Nostradamus74's Avatar
Nostradamus74
I do confirm, p.n. 44345-09, I have them on my BO too.
Old Jan 17, 2014 | 01:40 AM
  #146
BroTim's Avatar
BroTim
Thanks for the axle cover info.!
Old Jan 17, 2014 | 02:54 AM
  #147
Nostradamus74
I wanna see your chromed swingarm! Mine has been already sent to have it chromed so I'm extremely curious to see how it will look like! Pics, pics, pics!
Old Jan 17, 2014 | 06:26 AM
  #148
24v's Avatar
24v
Yes, it is the Harley contrast cut version.
I put black engine covers on mine today. I bought the cam cover, primary, and both trans covers in wrinkle black for cheap on craigslist. Then I took them to get powdercoated gloss black. Unfortunately, they were not from a Breakout. So, the side tranny cover is different. The cover on the Breakout is about 1/4" deeper. This would push the clutch mechanism to the left side of the bike more, disengaging the clutch when I bolted the cover on. So, I left the tranny covers chrome and switched the engine covers to black. I'm going to leave them like this for now and see how I feel over time. Then, if winter ever hits here I will decide if I want to pull the stock cover and have it coated with the next round, or leave it chrome.
Here's a few pics.
Old Jan 17, 2014 | 07:37 AM
  #149
BlessedHellride's Avatar
BlessedHellride
Slowly, but surely, I can see you're making your way to those fender struts. That, and the shifter arm, are pretty much all that's left. Edit: maybe the oil lines too.
Also, I think someone here sprayed their rear axle bolts with plasti-dip. I would go that route too, over the covers, or plasti-dip the covers. I priced the CVO covers at $70 each if I recall.
Old Jan 17, 2014 | 07:42 AM
  #150
24v's Avatar
24v
If I leave the tranny covers chrome, I think I will leave the oil lines too. Struts and shift arm are next, and maybe the trees.
