Finally picked mine up and got the first ride in!
Don't mind the stock air cleaner my RSD one didn't come in yet.
Now just to delete the rest of the chrome.
looks awesome man...delete n chrome as we speak myself
Great looking bike. Congrats
I am doing the same thing to my black breakout. Have fun
Looks so good lowered 2 inches. What did you use to lower it? Did you go new shock or just the lowering blocks on stock shock?
Great looking bike
Softailloweringkit.com... Uses same shocks, and you only remove the front nuts and sleeves, and replace them with collars between the canister and the frame. Then you use the supplied bushing that has a nut built into it. Easy! Didn't change the ride at all!
did you put risers on under your bar clamps?..and if so where or who makes them?...thanks good looking skoot!
So of course after my first ride, I installed the blackline dash and softtail lowering kit.
This morning go to start it and nothing!
Bike has the fobs not actual keys. And when ya turn the **** to run the lights will come on as normal but nothing on the run switch and bike has no speedo lights or anything.
Any thoughts. I'll be taking the dash back apart to double check it all but I've worked on much harder things and the dash was cake.
Thanks in advanced.
