Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 22, 2014 | 02:02 PM
  #461
jweinsteiger's Avatar
jweinsteiger
Originally Posted by 24v
I'm on it as soon as I need to replace the back tire.
How is the wear on your rear tire I have just over 4k on mine and looks like I may get around 8k before its due for replacement then I am going with the chrome turbines... can't wait
Old Mar 22, 2014 | 03:16 PM
  #462
24v's Avatar
24v
I am at about 6k and I bet there's at least a few more thousand in it.
Old Mar 22, 2014 | 03:53 PM
  #463
jweinsteiger
Are you planning on staying with the stock tire or going with something else?
Old Mar 22, 2014 | 04:59 PM
  #464
molnar70's Avatar
molnar70
Slowly getting there...
Attached Thumbnails The Everything Breakout Thread-20140322_174350.jpg   The Everything Breakout Thread-20140322_174356.jpg   The Everything Breakout Thread-20140322_174404.jpg   The Everything Breakout Thread-20140322_174412.jpg
Old Mar 22, 2014 | 05:16 PM
  #465
jweinsteiger
Looking good! keep moding............
Old Mar 22, 2014 | 06:45 PM
  #466
JimGnitecki's Avatar
JimGnitecki
Careful on tire size changes that involve diameter changes. The service manual specifically warns that you can impair the operation of the ABS system if you change the diameter.
2014 Breakouts come with ABS as STANDARD equipment.
Jim G
Old Mar 22, 2014 | 06:56 PM
  #467
24v's Avatar
24v
Fortunately, I have a 2013 with no ABS.
I am thinking about going to a Metzler 260 when I change. Hoping to fill the fender a little more.
Old Mar 22, 2014 | 07:20 PM
  #468
jweinsteiger
Do you know if the Metzler 260 needs any mods to fit? I like that idea myself
Old Mar 22, 2014 | 07:21 PM
  #469
24v's Avatar
24v
I have not seen anyone put one on a stock fendered Breakout. Only one way to find out.
Old Mar 22, 2014 | 07:38 PM
  #470
HKMark23's Avatar
HKMark23
Jim G
Not that I have plans regarding tires any time soon but I'm curious as to why this is and what they mean by diameter, (circumferential or sectional). Anyone got a "Tires for Dummies" explanation as to how this tires vs ABS works ?
Thanx
Did some reading, from HD manual:
Use only tires listed in Table 1-7. NOTE
ABS equipped motorcycles must always use properly inflated tires and wheels that are the same as the original equipment. The ABS system monitors rotational speed of the wheels through individual wheel speed sensors to determine the application of ABS.
Different diameter wheels or tires can:
  • Alter the rotational speed which can upset the calibration of the ABS.
  • Adversely effect its ability to detect and prevent lockups.
    Operating with inflation pressure other than those specified in Table 1-7 can reduce ABS performance.
Guess I was thinking only the real vs perceived (by the system) rate of deceleration would be less with a larger circumferential diameter but if it throws the ABS calibration off,,, ??
