Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 13, 2014 | 01:38 PM
  #361
Pa-Rider's Avatar
Pa-Rider
Originally Posted by EagleRay
Hi jackjr! Just wanna ask...what did you use to mount the solo bag to your swingarm. Leather straps, zipties or a mounting system like the bobber bracket by deadcreekcycles?
Currently I'm using the straps that came with the solo bag. I haven't put a lot of effort into finding a better solution, but at some point I'll probably go with a hard mount like the deadcreekcycles.
Old Mar 13, 2014 | 04:39 PM
  #362
sparky1075's Avatar
sparky1075
Originally Posted by jackjr
I know at least one of you guys have painted the ignition assembly (grenade mount). I've got it pulled back off again to install my new 50mm throttle body and FuelMoto PV2 and AT- Pro. I want to paint it before it goes back on but it doesn't look like the grenade comes apart from the mount. Am I missing something? I un-did the bolt at the bottom but it still feels like it's all one unit.
jackjr you have to remove the bolt at the bottom, remove the set screw from the ignition switch **** and finally use the ignition switch spanner wrench to remove the switch nut. The wrench is HD-48904 if you plan on getting one. Not sure what others might have used to remove it.
Old Mar 13, 2014 | 05:31 PM
  #363
Lindosan's Avatar
Lindosan
I use the Dead Creek mount with leatherworks bag and it works great.
Old Mar 13, 2014 | 07:08 PM
  #364
Pa-Rider's Avatar
Pa-Rider
Excellent, thank you. I knew I was missing something!
Old Mar 13, 2014 | 07:09 PM
  #365
Pa-Rider's Avatar
Pa-Rider
Just curious, with that mount, how much space is there between the bag and your swingarm?
Old Mar 13, 2014 | 07:33 PM
  #366
wickedweasel13's Avatar
wickedweasel13
6th Gear
Default 2014 Breakout Instrument Backlight
according to research you can change the colors , anyone know how this is done ? it isn't covered in the owners manual
  #367
Lindosan's Avatar
Lindosan
I can measure later, but take a look on my photos.......
If you dont use the Dead Creek spacers you can get it closer to the swing arm, but for me it works fine.
Old Mar 13, 2014 | 09:26 PM
  #368
JimGnitecki's Avatar
JimGnitecki
No, that's not correct - at least according to my Breakout owner's manual.
The replacement combination Tach with LCD digital speedometer, which I also have on my Breakout, DOES have that color change feature. There are 600 different shades theoretically, as you can dial up any color number from 001 to 600 I believe.
However, the manual for it warns you that the best visibility in bright sunlight is with the black and white scheme it come set to from its factory.
Jim G
Old Mar 13, 2014 | 09:38 PM
  #369
wickedweasel13
6th Gear
Default changing colors on Breakout
Jim G
My owners manuel doesn't mention color change option on factory speedo , even thou I've read quite a few articles about it, just wondering how to do it
Old Mar 13, 2014 | 09:42 PM
  #370
JimGnitecki
Again let me clarify: The stock factory speedometer on the Breakout does NOT have that color change feature.
The available tach-speedo does, but you have to buy that and replace your stock speedo with it.
I have not checked, but I suppose it is possible that the CVO version (only) of the Breakout has that feature???
Jim G
