Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 13, 2016 | 03:03 PM
  #4731
Mencho's Avatar
Mencho
Finally got rid of the reflectors, much better!
Old May 13, 2016 | 03:38 PM
  #4732
breakman's Avatar
breakman
Nice bike. Did you remove the plastic on rear fender and if so how hard was it?
Btw taking off the reflectors will void your warranty.
Old May 13, 2016 | 04:08 PM
  #4733
Mencho's Avatar
Mencho
Well for the rear reflector you need to take the fender off. I have read some other options but this was the most effective one. It will take some time but not impossible.
I never heard about that but will take the risk on the warranty, it just ruined the bikes look .
Old May 13, 2016 | 04:15 PM
  #4734
cdonis's Avatar
cdonis
If you are going after the fender , remove it by unplugging the plugs to the lights, uderneath the seat. Remove the 4 fender strut bolts located near the the oil tank. Gently spread the struts over the tabs and remove it in one piece. Takes about 10 minutes
Old May 13, 2016 | 07:10 PM
  #4735
Da-Rza 21's Avatar
Da-Rza 21
10 hp gain with reflector removal
Old May 13, 2016 | 08:55 PM
  #4736
the_enforcer's Avatar
the_enforcer
Dang you only got 10hp gain? I ended up with a solid 16hp gain. I had to get it retuned afterwards cause it was running like grab with the unlocked power
Old May 14, 2016 | 04:03 PM
  #4737
splattttttt's Avatar
splattttttt
Originally Posted by wedgemoose
WOW HK, you answered my questions exactly as I needed them answered. All my concerns are covered now. You also just saved me $400. You are the man sir!!!!!!
Now to find them. Thanks again
P.S. I never answered your first reply about wiring. Yes I can wire anything. That wasn't the problem. You answered all the problems that were stopping me from doing it this way.
thanjed HK for ya cause you is homie, C'ya roun brah
Old May 14, 2016 | 04:05 PM
  #4738
splattttttt
evah try eunnin w/out a perch? Esasy 20hp gain
Old May 14, 2016 | 08:46 PM
  #4739
slowride2016's Avatar
slowride2016
Default Ready for 2-up riding
I added a HD detachable sissy bar along with a Fatboy rear pillion pad. Took some minor mods to the pillion to make it fit but picked it up for $40 so it was worth the effort. The OL was much happier riding on the back and it takes seconds to switch things back to solo running configuration. Sissy bar was purchased locally from another member so I have less than $200 invested for comfy 2-up riding.
For anyone looking, the stock Fatboy pad matches the stock seat much better than the Sundowner and the OL says it's very comfortable. It came off an '11 Fatboy but I'm sure other years would also work. The slots that fit the factory mounts have to be extended and plastic trimmed so it doesn't dig into the front seat. Took me 10 minutes with several test fits before I got it right but I didn't want to risk trimming too much.
Old May 14, 2016 | 08:54 PM
  #4740
tibnyi01's Avatar
tibnyi01
Had to move on from my Breakout rather quickly but as much as I love it, it wasn't what I needed in a bike.. at least if I could only afford one. So I move to the Touring section but will still be looking at everyone's great rides and sick mods! Cheers!
