Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 10, 2016 | 01:30 PM
  #4721
EagleRay's Avatar
EagleRay
Originally Posted by LA_Dog
that trick is for the older bikes with TSSM module. the BSM will learn the correct bulb flash rate right away, but will still flash the dash indicators at a fast rate.
Yep, mine does the same! Tried the procedure in different ways but still the dash indicators keep on flashing fast...But I was wondering if it would make a difference installing those LED signals with or w/o load equalizers....
AFAIK user Nostradamus74 installed LED signals and his dash indicator works fine after doing the hazard light procedure.
Old May 10, 2016 | 01:36 PM
  #4722
LA_Dog's Avatar
LA_Dog
^ NSR - I see what you mean- this type of lens design would work better, assuming of course the mfr actually centered the LEDs behind the lens elements. http://www.ebay.com/itm/1PC-Bike-Bla...-/141937652848
a lot of the china clones have very "loose" QA tolerances on aligning the LED with the lens. if it's off even 1mm it screws it all up. plus the backside of the one in the link above probably will not fit our smaller buckets.
Old May 10, 2016 | 01:40 PM
  #4723
NSR's Avatar
NSR
Yep LA - I guess I was thinking ... "a little more $$ means a better light". Maybe I was wrong...it happened once before, lol....
I'm not too worried about the light, really. It'll be OK ... the Hi Beam is great!
Next up are some primary and final drive mods...this fall.
Old May 10, 2016 | 01:47 PM
  #4724
LA_Dog's Avatar
LA_Dog
that's odd- typically the load equalizer resistor and/or hazard trick only applies to the TSSM bikes. but mainly because on those bikes the LED bulbs themselves don't flash at the correct rate.
Wait... is there actually a low beam? I never use it.. LOL
Old May 10, 2016 | 01:53 PM
  #4725
NSR's Avatar
NSR
Heh ... yep, it's Hi-Lo. I always ride with the Hi on too. Don't we all? I was just goofing around with it last night on Lo. That's how I noticed the weak center with the Lo beam.
Old May 10, 2016 | 01:55 PM
  #4726
LA_Dog's Avatar
LA_Dog
^^LOL yeh i'm just being a goofball. I always run with high beam on.
Old May 11, 2016 | 10:39 AM
  #4727
wedgemoose's Avatar
wedgemoose
Originally Posted by HKMark23
You splice the wire at an external point outside both the switch and light housings. Instructions and some shrink tubing are included with the light. When completed, you're the only one who will know the wire is spliced.
If you have a friend in the electronics trades, or who is mechanically inclined and has worked with automotive wiring, show them the instructions and they'll knock this little job off within 20 min total. If you can manage wire cutters, a soldering iron and a hair dryer and can follow very simple and explicit written instructions you'll be fine. There are 2 wires per light, one red, one black and nothing explodes if you cut the wrong one first .
HK, I finally looked at my bike yesterday to see what i was concerned with before. I know what it is now. The grommets was the part i'm worried about. There is a grommet on the blinker and the switch housing, And they look like it's part of the OE wire. So what is your method like? is it a hole in the blinker and switch housing? Or do they supply a grommet type thing with the kit? I am particular about stuff like that. I wouldn't want the wires just going into a open hole.
I did find out the OE way to do it but it will cost me $400 (Fat Bob blinkers are chrome and use the same switch setup as mine).
Old May 11, 2016 | 11:58 AM
  #4728
HKMark23's Avatar
HKMark23
The instructions which come with the lights are very explicit and straight forward but unfortunately, now that I'm done with them, I no longer have them. IIRC, you cut the existing wire flush with the grommet at your existing light housing. Then you slide the heat shrink tubing over the remaining wire protruding from the switch housing (3 pieces) , splice (solder) the (new light/switch housing) wires together as required, then slide each piece of shrink tubing in place per instructions and shrink them with your heat gun or hair dryer. The final piece of shrink tubing covers the entire splice. You don't need to get into the guts of your switch or light at all. The splice is external to both.
Instructions for trimming of wires to necessary lengths to effect a good looking splice are with the new light kit.
Old May 11, 2016 | 06:03 PM
  #4729
LA_Dog's Avatar
LA_Dog
came across some cool new 1157 led bulbs on amazon, $14/pr, tested them out. pretty nicely made and hella bright- very good diff between brake and tail light levels. pics and info posted in a related thread here:
https://www.hdforums.com/forum/softa...l#post15135783
Old May 12, 2016 | 12:47 PM
  #4730
wedgemoose's Avatar
wedgemoose
WOW HK, you answered my questions exactly as I needed them answered. All my concerns are covered now. You also just saved me $400. You are the man sir!!!!!!
Now to find them. Thanks again
P.S. I never answered your first reply about wiring. Yes I can wire anything. That wasn't the problem. You answered all the problems that were stopping me from doing it this way.
