I have a 2012 Fat Boy Lo with about 12,000mi. I've been having to hook it up to a battery tender in order to get it started. Today, even after being on the tender for a week, it wouldn't start. This all started when the weather got cold. I know the cold can effect the battery but DH's 2003 Softail Standard sits right next to it and his bike starts like a top with a battery older than mine!
Could something be draining the battery? There's been nothing new or changed so why the sudden problem?
Sound's like it's just a bad battery. That's where I'd start. If your still under warranty talk to the dealer. Remember that the tender is not really a 'charger'. It maintains. You'll probably burn up the tender trying to bring a low battery up.
My battery tender charges as well as maintains it at full strength. If you have had your battery tender hooked up for a week and it still wouldn't start I'd check the battery to see if was good and getting fully charged. I would also check the connections both from the battery tender to make sure that it is doing it's job and also check your battery connections to make sure that the power from your battery is getting to your starter. Another idea I just thought of, is your battery tender working properly, maybe it has a defect in it so it's not doing it's job properly either.
Aside from the battery tender check your voltage regulator it could be only putting out just enough voltage to run the bike and not enough to charge the battery. Check to see if your bike is covered on the recall of the voltage regulator
Is it common for a battery less than 2 years old to go bad?
Battery life depends more on how the bike is ridden. A bike that sits in a garage on a tender and not ridden much will last 6 + years.
A bike ridden every day especially in the heat, especially a Softail with the battery in the oil tank where it gets extreamely hot will last two/three years.
