Dipstick blues
Old Dec 23, 2013 | 11:03 AM
Ramboamt's Avatar
Ramboamt
Possible crank case pressure building up in the oil tank?
Check the crank case vents to see if they are plugged.
Old Dec 23, 2013 | 11:14 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I've never heard of this or had it happen to me. The old old tank dipsticks screwed in, not push in like now, so it's no wonder some have popped out. Be glad you weren't going down the road when it happened.
Old Dec 23, 2013 | 12:27 PM
rideflhr's Avatar
rideflhr
2012 Deluxe.I have the HD (Chinese?) temp dipstick,have had a lot of them and they all fit fine.The new one seemed loose but it never came out so I didnt think about it. Untill it came out on the road and dumped at least a qt of oil all over the side of my bike.What a mess.Hard to get burned on oil off exhaust&WWW.Brakes needed changed.
I went in a NAPA store when this happened and bought an "O" ring,put it on and it fits tight now. The stock one fits tighter than the crappy HD one.
Old Dec 23, 2013 | 06:39 PM
harleydavis's Avatar
harleydavis
Buy a thin O ring and put it in the grooves of the dipstick cap. It will help the seal.
Old Dec 23, 2013 | 06:46 PM
Sgt_Jim's Avatar
Sgt_Jim
Happened to me on my last ride.. Don't know what caused it, i know the oil level is right. When I got home, I noticed the dipstick was hanging there..my leg was the only thing that stopped it from flying away..had oil all down the side of the tank and dripped on to the exhaust.
Old Dec 23, 2013 | 07:20 PM
threadstopper's Avatar
threadstopper
I used a couple of wraps of self amalgamatimg tape to improve the fit of my temp gauge dipstick no more leaks or surprise removals.
Old Dec 24, 2013 | 12:58 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Originally Posted by UT-rckr
I have heard of this before and it's usually due to overfilled oil.
This is what I have always been told would cause this. It has luckily never happened to me.
Old Dec 24, 2013 | 09:00 AM
mustang125's Avatar
mustang125
I am wondering if when drying the muffler you blow air into the exhaust pressurizing the crank case. This caused the dipstick missile. My 09 leaks oil out of the dipstick on every trip. I am planning on replacing it but might just try the o ring trick till I can get the one I want.
Old Dec 24, 2013 | 09:06 AM
EP50's Avatar
EP50
Its possessed...send it to me and I'll exorcise it for you
Old Dec 25, 2013 | 03:16 PM
The88Beast04's Avatar
The88Beast04
Good thing the new ones just push in then, or else something else would popped or busted in his engine. That would've sucked worse
