Another "Progressive Spring Install Help" Post
Old Dec 29, 2013 | 05:41 PM
SwiftyBKells's Avatar
SwiftyBKells
Exclamation Another "Progressive Spring Install Help" Post
I've googled, searched, etc. and still stuck...
1. How do I get the fork seals all the way in?
2. How do I know when they are in as far as possible?
- I tried the PCV trick, a pipe, a screw driver +hammer & not 100% sure I got it right.
3. Does a pin go inside the seal itself? It has an indented ring inside the seal that looks like one would go inside but I don't remember seeing one and I couldn't find one when I googled.
4. How do I get the metal odd shaped ring to sit above the seal?
5. Do I add fork oil then the springs or the springs and then fork oil?
Pics included cause I know i'm horrible at describing things. Any help is appreciated!!
Attached Thumbnails Another "Progressive Spring Install Help" Post-img_1725.jpg   Another "Progressive Spring Install Help" Post-img_1729.jpg
Old Dec 29, 2013 | 06:53 PM
KumaRide's Avatar
KumaRide
You should get a manual. The pvc trick works great. Ring sits on top of seal. You can see the small indents inside the fork tubes, above the seal, where it snaps into place. The ring snaps only a little way into the indents. If the ring wont snap into place, the seal is not in all the way.
Old Dec 29, 2013 | 07:56 PM
QC's Avatar
QC
Seal is in far enough when you can snap the spring clip into its groove.
Springs in, then oil.
Old Dec 29, 2013 | 10:30 PM
Shakey Softail's Avatar
Shakey Softail
All right there is a groove in the fork slider that the ring goes into the seal only goes in so far be careful the seals can damage easy
maddyv
Mar 11, 2016 01:00 PM
S.D.M.F
Oct 24, 2013 03:07 PM
flhxmc
Jan 22, 2013 10:32 AM
Dep
Jun 26, 2011 08:01 PM
jarhead45
VRSC Models
Aug 30, 2010 07:04 PM
