2012 Heritage performance
Old Jan 1, 2014 | 11:15 AM
Ed Davis's Avatar
Ed Davis
Stage II
Default 2012 Heritage performance
New Harley performance
I've rode a lot of miles and have had quite of few bikes but after cruising across our country I have found Harley gave a smooth ride and good MPG. I now ride a 2012 FLSTCI and can tell you what a disappointment with performance and mpg. I've had 4 touring Harleys previous and the 88cu.in Road King had better mileage pulling the same small trailer as the 103cu.in Heritage and better power. Now I've had the same weight and performance additions on almost every single Harley. 2003 Road King 42 mpg no trailer/38 with trailer, 2012 Heritage 38mpg no trailer/ 25 with trailer. I had Dynojet which was in Sturgis checked the bike and they ran the numbers and said they did a little adjustments but not much. Now many of you are going to tell me rubber mounted versus counterbalance shaft motor which I get all of that. So I think Harley should make a Heritage with a touring motor/rubber mounted for 2015. If you can help with this problem let me know..
Old Jan 1, 2014 | 11:36 AM
Superfly3176's Avatar
Superfly3176
I'll get the designers right on that. do you want a turbo with that motor as well?
Old Jan 1, 2014 | 12:02 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
I get over 40mpg with my 12 Heritage.
Old Jan 1, 2014 | 02:43 PM
oct1949's Avatar
oct1949
Thinking you have a tuning issue.
07 Heritage and she always gets 43-47 riding two up, not much difference between putting around at 35 in 3rd-4th or on the hi-way in 6th.
After I did the stg1, cams and dyno she improved to above (43-47) from 40-44 when stock.
Old Jan 1, 2014 | 03:06 PM
Tailsfrommycrib's Avatar
Tailsfrommycrib
40 to 45 mpg at 2500 rpms. Why would Harley make a heritage with a rubber mounted engine when they already have the road king. Also the rubber mounted engine can't fit in a softail frame (thank God), and if you liked the tourers so much why did you get a softail in the first place. I will never own another bike with a rubber mounted engine. My wife hates the vibrations at idle and I prefer the relatively smooth B engine too.
Old Jan 1, 2014 | 03:17 PM
checkers's Avatar
checkers
Ethynol fuel, tuner or tuner timing, tire pressure, and right hand are what's causing your lower mpg. Run pure premium gas, remove the tuner, air up tires to 41lbs and stay off the throttle. You will get about 40-42 mpg on the 103. (not pulling a trailer)
Old Jan 1, 2014 | 09:12 PM
oct1949's Avatar
oct1949
you don't need a rubber mounted (B) motor...
I still think you are have a tuning issue.
Old Jan 2, 2014 | 04:33 AM
PitBullMcCoy's Avatar
PitBullMcCoy
I can't speak for the newer bikes at all because I've never ridden one, and this may not even matter but its an example none the less. My '00 model averages 32mpg. The engine is upgraded to 96" and I ride the ever lovin sh*t out of her. Love the sound and power she makes in third at 3k-4500 rpms on little curvy back roads. That's her sweet spot! My point being I have loads of motor work. A stock bike should be better I would think but that's all I can say from my personal exp.
Old Jan 2, 2014 | 11:17 AM
byersmtrco's Avatar
byersmtrco
I also have a 2000 Heritage.
I had an 02 Electra Glide for about 6 months.
(Had to sell it - not really by choice)
My Heritage (carbureted) avrg's 35 mpg (40 tops)
The EG is smoother on the freeway, but the Heritage
is actually easier to ride.
And it's a better ride on country back roads.
I do miss the fairing though.
HDJIM1158
Jun 12, 2018 02:06 PM
liquidr1
Oct 6, 2014 09:56 PM
chris42795
May 16, 2014 12:33 AM
2002flstc
Motorcycles For Sale
Jan 11, 2009 07:57 AM
dgb
Aug 17, 2006 11:42 PM
