Internal Handlebar Wiring
Old Jan 11, 2014 | 12:56 AM
soft 02's Avatar
soft 02
Originally Posted by Citoriplus
They must have changed the hose between 02 and 07, cause you would not be able to do that with mine.
The hose is all plastic and if you don't disconnect it from the tank it breaks off the back of the injector manifold.
I was dumb and didn't disconnect it and I broke it.
Yea cause mine is a rubber fuel hose. If it happens again switch out for a rubber one. It handles the pressure fine and makes for an easy fix on the road.
Old Jan 11, 2014 | 10:53 AM
Dake's Avatar
Dake
That chain thing is awesome I have wasted a lot of time blowing a string though.
Old Jan 11, 2014 | 08:45 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Not likely, there are special clip fittings on the ends, not barbed tubing like your's.
Might have to take the tank and the injectors out and refit them for that to work.
And that's more trouble than its worth if all I have to do is make sure I don't stick my head up my *** to not have a problem.
Old Jan 11, 2014 | 08:50 PM
soft 02's Avatar
soft 02
Wait. We both have 07's. Strange. Too bad. Oh well.
Old Jan 11, 2014 | 11:25 PM
Now I'm just confused.
Must be the old age setting in.
Old Jan 12, 2014 | 10:39 AM
Benway's Avatar
Benway
Where you all getting your wiring extension? I'm looking at this: http://www.ebay.com/itm/LA-Choppers-...-/231127701084
Old Jan 12, 2014 | 10:42 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
The inner wiring, taking the controls off of the bars, getting it all back together AND working, is what's keeping me from changing my bars. That and no money to get the bars.
Old Jan 12, 2014 | 11:11 AM
Benway's Avatar
Benway
I've had the controls off the bars a half dozen times. No problem there - the wires stay with them.
Also, cutting the wires out of the harness and extending them is no biggie: You do one wire at a time and use color coded wires if possible. Solder all connections and use shrink tubing. (I use to run wiring harnesses in aircraft, front to back and then wire up 50 pin plugs, so I'm not expecting much trouble here once I get my parts in order)
Bar expense is another issue, though the ones in my pic sig were about $170 and my old bars (RK touring replacements) where $39 from JP, the Wild 1s pushed $200. What I can't get behind is $350 for Carlinis AND another $200 for their risers (since they don't shrink the bars at the clamp so you could use stock risers). And you can double that (or triple) if you have someone else put them on for you. And who only ends up with ONE set of bars? Too rich for my blood.
Old Jan 12, 2014 | 02:56 PM
Benway's Avatar
Benway
Just put the bars in place to see where I stand. Something I hadn't even considered is that I'm going to need new throttle cables. Existing cables are a mile too short. The tank definitely has to come off now... Clutch cable looks to have plenty of length.
Bars fit well, though. Sitting on the bike, grips are at or slightly above shoulder height. If I used the stock seat, I could have went with taller bars, but with the LePera, they're perfect. Won't make as much of a statement, but they'll be a lot more comfortable and I won't have to sit straight up to reach them (hate sitting straight up on a bike).
Old Jan 14, 2014 | 08:40 AM
Benway's Avatar
Benway
Any recomended places to order Throttle Cables from?
